ProjeQtOr free project management software - Real-work Allocation issue - ProjeQtOr
06 Nov 2015 14:03 #1 by nicol9
I try ton use real-work allocation in v5.1.1 and I have some problems to use it on Chrome
I input some values with coma : 0,5 or 0,25
When I do the input and save no problem (see Diapositive 1).
If I go to another screen and come back on my Real-work allocation, Projeqtor didn't display my different inputed values and the sum is also not displayed. (see Diapositive 2)
08 Nov 2015 12:25 - 08 Nov 2015 13:11 #2 by babynus
Replied by babynus on topic Real-work Allocation issue
I cannot reproduce.
It is sure there is a problem as there should not be "blank" cells, zero values should appear as zero...
1) Could you try and reproduce on Demo ?
2) Could you please check for errors in the browser console or in the log file ?
3) Could you check values stored in database (and post values here ?
Thx
Last edit: 08 Nov 2015 13:11 by babynus.
09 Nov 2015 16:59 #3 by nicol9
Replied by nicol9 on topic Real-work Allocation issue
1 ) It's almost OK : just the information show in column Real and Reassessed are not totaly good because the 0 is not displayed
2) Any message
3) I couldn't access to the database
I use Chrome
10 Nov 2015 09:23 #4 by babynus
Could you give more hints about your test : which use did you connect with, which day did you enter work, on which line, ...
2) Any message
Do you mean no message ?
Could you post log file ?
It will be hard to analyse withouit reproducing on demo and with extra information. Maybe your db format is not as expected so it would be very usefull to get information about your db.
I use Chrome
So do I.
I don't think it is a browser dependent issue (unless you reproduce only on chrome and not on other browser.
Just to be sure, could you try again after disableing all extentions and plugins in the browser ?
(some extensions such as "Skype click to call" are known to set a mess in the application)
02 Dec 2015 11:37 #5 by nicol9
I have new element.
When I input 0,5 in a cell, I can save my real-work allocation and after saving the value displayed is ok.
When I change my inputaion week and come back to the precedent where I inputed my 0,5, my cell is always empty.
BUT, now I try to modify my 0,5 by an other value with a coma (ex : 0,25) and in the column Real I've got "NaN" displayed.
I made the update in v5.1.4. (cg attachment)
Thank you for your help
03 Dec 2015 10:42 #6 by babynus
Do you have PphMyAdmin ?
How does it display work.work (field work in table work) for concerned lines ?
(for instance add new decimal value and check line with highest id)
