ProjeQtOr free project management software - Real-work Allocation issue - Page 3 - ProjeQtOr
07 Dec 2015 11:38 #13 by nicol9
Replied by nicol9 on topic Real-work Allocation issue
For the ticket in real work allocation, the value 0,5 is not displayed
In the detail of activity after saving, the value is no more displayed.
07 Dec 2015 11:44 #14 by babynus
Replied by babynus on topic Real-work Allocation issue
Thanks it gives me some hints.
Other question if you "print" Ticket or Activity, do you see correct value or not ?
07 Dec 2015 11:51 #15 by nicol9
When I print an activity, a ticket or the real work allocation the value is well displayed.
07 Dec 2015 12:05 #16 by babynus
Thank you.
Could you please have a test :
In /projeqtor/view/objectDetail.php, add 1 line before line 965, from this :
echo ' value="' . htmlEncode($val) . '" ></div>';
to
traceLog("$col=$val=".htmlEncode($val));
echo ' value="' . $val . '" ></div>';
Then try again to display Ticket with non displayed decimal value.
Does it display correcly now ?
What is is the log file ? (please post log file content here)
Thank you.
07 Dec 2015 12:44 #17 by babynus
What is you PHP Version ?
If it is 5.6, can you please check pnp.ini, what is value for default_charset ?
09 Dec 2015 17:10 #18 by babynus
Found issue.
It seems to happen on PHP 5.6 (could reproduce on PHP 5.6 but could not on PHP 5.5)
Fix is to add new line after line 61 in /model/NumberFormatter52.php :
    setlocale(LC_NUMERIC, 'C');
    if (array_key_exists('browserLocaleDecimalPoint', $_SESSION)) {
      $this->decimalSeparator=$_SESSION['browserLocaleDecimalPoint'];
Fix will be deployed in Patch 5.1.5 (coming soon)
