ProjeQtOr free project management software - Installation problem with Postgresql 5.0.2 projeqtor under CentOS 6.7 x86_64 - ProjeQtOr
27 Jul 2015 10:52 - 14 May 2016 10:20 #1 by Mams
Hi everyone
Installing CentOS 6 projeqtor under x86_64 and postgresql 9.4 does not. I took the parameters in configuration in the "main view" GUI, and the system hangs. The log file is empty. :(
Can you help me?
Thanks for your answer.
Last edit: 14 May 2016 10:20 by Mams.
28 Jul 2015 09:40 #2 by babynus
Please check all prerequisites.
For instance mbstring is sometines missing.
Also give more hint :
the system hangs : for me it means the server is blocked, which is very serious
I guess it is not so serious, so please describe exactly the issue : step by step use case, exact behaviour, ...
28 Jul 2015 22:58 #3 by Mams
Find in attachment the files which show the modules installed, then the interface of the configuration parameters. While pressing on “OK” button, it occurs anything, no error message, no log.
Note: the Apache server
File Attachment:
File Name: phpandapac...ules.txt
File Size:4 KB
functions correctly.
28 Jul 2015 23:41 #4 by babynus
1) Modules seem to be installed, but maybe they are not defined in php.ini
Best way to check is to define a new file info.php with just
<?php phpinfo(); ?>
then call the page
2) check errors in the browser console
3) check errors in apache logs
29 Jul 2015 22:44 - 01 Aug 2015 09:28 #5 by Mams
Find in attachment, the phpinfo and apache logs files.
Thank you so much for your help and your response.
Best regards
File Attachment:
File Name: apache_log...info.zip
File Size:12 KB
Last edit: 01 Aug 2015 09:28 by Mams.
01 Aug 2015 09:35 - 01 Aug 2015 09:37 #6 by Mams
I try again all the process of installation with the emptying of the mask firefox, and I am always blocked.
Apache logs and phpinfo are OK without error (to see file in attachment).
Can you help me please?
Thank you so much
File Attachment:
File Name: apache_log...fo-2.zip
File Size:12 KB
Last edit: 01 Aug 2015 09:37 by Mams.
