ProjeQtOr free project management software - Installation problem with Postgresql 5.0.2 projeqtor under CentOS 6.7 x86_64 - Page 2 - ProjeQtOr
01 Aug 2015 17:04 #7 by babynus
PhpInfo show all needed modules...
No error in apache error log...
1) Can you check if a button did appear on bottom of scren (maybe scrolling bar is just hidden)
2) Chesk for arrors in the browser console (report here any error)
3) In network console, check last request send (url called) and response retreived and post it here.
07 Aug 2015 10:11 - 07 Aug 2015 10:11 #8 by Mams
The scroll bar appears
No error found
I do not know how to do, because I'm not an expert in IT
Thanks for your help and your response
Last edit: 07 Aug 2015 10:11 by Mams.
07 Aug 2015 11:23 - 07 Aug 2015 11:25 #9 by babynus
Please try v5.0.4 : it includes new check for prerequisites (initially planned on V5.1, included in V5.0.4 to avoid missing prerequisites issues).
Maybe it can give some hints.
Last edit: 07 Aug 2015 11:25 by babynus.
07 Aug 2015 22:56 #10 by Mams
I tried the 5.0.4 with the parameters for postgresql 94, I do not have any message for the prerequisites. The configuration is always blocked.
08 Aug 2015 12:55 #11 by babynus
Ok,
Let's do it step by step.
I guess that what you do is :
=> copy zip file into web directory of http server
=> run projeqtor into browser => you get the configuration page
=> fill in informtation (at least the database and log file information)
=> click on button "OK"
Correct me if I'm wrong...
Please detail what happens when you click on button "OK" :
1) absolutely nothing
2) a spinner appears for short time, then desepears : if so, is there a message and new button under "OK" ?
3) a spinner appears and never disepears
4) other behavior
08 Aug 2015 22:03 - 08 Aug 2015 22:03 #12 by Mams
Yes, it is that. The behavior correspond at the step 3. But, there is no error message under button “OK”.
Last edit: 08 Aug 2015 22:03 by Mams.
