ProjeQtOr free project management software - Issu on installation - ProjeQtOr
20 Aug 2011 10:59 #1 by Guest
Issu on installation was created by Guest
I try to install on Linux Ubuntu 11.04.
I have this message on intall screen :
incorrect value for 'Parameter file name', does not include a valid directory name
I change it to /home/projects/files/config/parameters.php
Do you have a idea ?
20 Aug 2011 13:43 #2 by babynus
Replied by babynus on topic RE : Issu on installation
In your case,directory /home/projects/files/config must exist, and user running php must have write access to it.
Regards.
20 Aug 2011 21:45 #3 by Guest
Replied by Guest on topic RE : Issu on installation
Thanks, any change after i create this directory.
A other way ?
20 Aug 2011 21:56 #4 by babynus
Try a "chmod 777" to this directory, to be sure you don't face an access issue.
Is the message always the same ?
21 Aug 2011 08:27 #5 by Guest
Error message :
"incorrect value for 'Parameter file name', does not include a valid directory name"
malatesta@cymerp2011:/home/projects$ ls -afg
total 12
drwxrwxrwx 5 www-data 4096 2011-08-20 21:24 files
drwxrwxrwx 10 malatesta 4096 2011-08-20 10:40 ..
drwxrwxrwx 3 www-data 4096 2011-08-20 10:40 .
malatesta@cymerp2011:/home/projects$ cd files
malatesta@cymerp2011:/home/projects/files$ ls -afg
total 20
drwxrwxrwx 3 www-data 4096 2011-08-20 10:40 ..
drwxrwxrwx 2 www-data 4096 2011-08-20 21:43 logs
drwxrwxrwx 2 www-data 4096 2011-08-20 10:42 attach
drwxrwxrwx 2 www-data 4096 2011-08-20 21:30 config
drwxrwxrwx 5 www-data 4096 2011-08-20 21:24 .
malatesta@cymerp2011:/home/projects/files$ cd config
malatesta@cymerp2011:/home/projects/files/config$ ls -afg
total 8
drwxrwxrwx 5 www-data 4096 2011-08-20 21:24 ..
drwxrwxrwx 2 www-data 4096 2011-08-21 08:22 .
my directories details all seems ok...
21 Aug 2011 15:10 #6 by babynus
All seems right.
Could you send me your a print screen of you config screen, after having removed confidential settings (access to database,..) ?
Thx.
