ProjeQtOr free project management software - Issu on installation - Page 2 - ProjeQtOr
21 Aug 2011 19:18 #7 by Guest
Replied by Guest on topic RE : Issu on installation
Let me know your email adress.
21 Aug 2011 19:37 #8 by babynus
Replied by babynus on topic RE : Issu on installation
This email address is being protected from spambots. You need JavaScript enabled to view it.
22 Aug 2011 13:36 #9 by Guest
Is done have you received ?
22 Aug 2011 17:50 #10 by babynus
Yes,
I received your information. Thx.
Nothing wrong appears. Still investigationg.
22 Aug 2011 18:04 #11 by babynus
Can you check php.ini : is the safe mode enabled ?
safe_mode = On
If so, you must either set it to off
safe_mode = On
or add your directory in safe_mode_include_dir
safe_mode_include_dir=/home/projects/files
22 Aug 2011 23:55 #12 by babynus
I finaly found ! It's a programming issue.
In fact this does not appear if your way to the parameter is relative (../../../home/project/file).
So its one way to have a work around : define a relative (and not absolute) path.
Other solution : correct /tool/checkConfig.php, line 84, replace
if (! $rep or $rep='.') {
with
if (! $rep or $rep=='.') {
This fix will be included in V1.7.0.
Regards.
