ProjeQtOr free project management software - Issue upgrading to V5 - Page 3 - ProjeQtOr
19 Jul 2015 18:42 #13 by babynus
Replied by babynus on topic Issue upgrading to V5
Must understand what happens in browser.
1) open browser dev tools : [F12] key works on most browser (I would recommend Chrome or Firefox fir debugging)
2) You should have a network tab on the tools : select it
3) play test on Projector
4) go ot network tab ; you should see all requests send to the server
5) select the last request (getHash.php if your test case reproduces the same way)
6) you should have on the right part several tabs, select the response tab
7) paste response on the forum
21 Jul 2015 15:37 #14 by briandlees
Replied by briandlees on topic Issue upgrading to V5
Unfortunately there was no response. Please see attached which have all the info that was available. i think perhaps the Error 500 Internal Server Error is as much info as we are going to find.
21 Jul 2015 16:16 #15 by babynus
Sure, empty response of getHash is not normal.
Sure you must have an error logged on projeqtor log file or apache log files.
1) make sure mbstring is correctly installed on your PHP
2) Try to install attached patch : unzip and copy/pasted getHash.php in /tool folder (replacing existing one). Try again connection. Retrive projector log file and post it here.
22 Jul 2015 20:46 #16 by briandlees
Well, we finally got there! It was the lack of mbstring which was obviously an issue for V5 but not V4.5.7. Everything appears to be fine now.
Thanks very much for all your patience and assistance. Sorry that it appears to have been my fault.
27 Jul 2015 19:08 #17 by babynus
For information, in V5.1 we'll add a systematic control of prerequisites.
=> on setup
=> on each upgrade (to take into account possible new prerequisites)
28 Jul 2015 10:41 #18 by briandlees
I think that's great news. For me I am running ProjeQtOr in a VM so I only install the minimum necessary packages to keep it light.
