ProjeQtOr free project management software - Issue upgrading to V5 - ProjeQtOr
16 Jul 2015 12:05 #1 by briandlees
I have been running successfully V4.5.7 on a SUSE V13.2 VM with postgresql and tried to upgrade to V5.0.3 but could not get past the 'Upgrade in progress' screen. I decided to start from scratch so I deleted the projeqtor database, deleted the installation (all below /srv/www) and tried again, but with the same issue.
I followed the same procedure but this time installed V4.5.7 which worked OK; I logged in, created a user and created a project. I then tried upgrading to V5.0.0 but again got stuck at the 'Upgrade in progress' screen. Everything looked good in the log files until the message:
2015-07-15 23:12:02.671 ***** ERROR ***** Exception-[42703] SQLSTATE[42703]: Undefined column: 7 ERROR: column message.showonlogin does not exist
LINE 1: select * from message where message.showOnLogin='1' and mess...
2015-07-15 23:12:02.677 ***** ERROR ***** For query : select * from message where message.showOnLogin='1' and message.idle=0
2015-07-15 23:12:02.738 ***** ERROR ***** Strack trace :
2015-07-15 23:12:02.859 ***** ERROR ***** #0 Sql->query called at [/srv/www/projeqtor/model/persistence/SqlElement.php:1578]
2015-07-15 23:12:02.940 ***** ERROR ***** #1 SqlElement->getSqlElementsFromCriteria called at [/srv/www/projeqtor/view/login.php:38]
2015-07-15 23:12:02.971 ***** ERROR ***** #2 include called at [/srv/www/projeqtor/tool/projeqtor.php:170]
2015-07-15 23:12:02.000 ***** ERROR ***** #3 require_once called at [/srv/www/projeqtor/view/main.php:37]
Please could you point me in the correct direction to fix this?
16 Jul 2015 22:07 #2 by briandlees
Replied by briandlees on topic Issue upgrading to V5
I have some more information. I have a test environment on my laptop using EasyPHP which includes mysql database. In the attachment messages_mysql.png you can see the structure of the table messages (using PhpMyAdmin) and there are 9 columns.
However, in the attachment messages_pgsql.png (using pgAdmin III) you can see the structure of the table messages in the production server which uses postgres. There are only 8 columns and the showOnLogin column is missing.
Obviously I can easily add the column but my questions are:
1. Why the difference?
2. How do I know that there are no other issues as the database upgrade obviously didn't work properly?
16 Jul 2015 22:18 #3 by briandlees
16 Jul 2015 23:18 #4 by babynus
Replied by babynus on topic Issue upgrading to V5
I think that your MySql database is in V5.0, and your postgres still in V4.7.
You can check this in table parameter, line with parameterCode='dbVersion'.
Column showOnLogin is added on V5.0.
Logged error for ongoing deployment should not be blocking, but it is strange as it should not be displayed.
Maybe you should try with a clean session (clering cache and cookies, or using different broser for setup)
Please decribe your config : server OS, PHP version, postgres version, ...
NB : I recently upgraded a postgres install from V4.4 to V5.0 without issue
17 Jul 2015 11:09 #5 by briandlees
You are correct; the dbVersion is 4.5.6.
openSUSE 13.2 (Harlequin) (x86_64)
psql (9.3.6)
PHP 5.6.1
I have already tried clearing browser cookies etc.
17 Jul 2015 19:55 #6 by babynus
Try and change line 34 /view/login.php to
if (1 or getSessionValue('setup', null, true)) {
This should be an workaround, that you should remove after correct upgrade.
