ProjeQtOr free project management software - [SOLVED] Text not being displayed on List Element Box - ProjeQtOr
14 Jul 2015 12:27 #1 by iconic
A few hours ago, when I click on LInk Activity, then click on the magnifying glass, the List Element Box shows there are activities I can select from, however all the content is displayed with - - -
It does not show any of the text information.
I have attached an image so it can show you what I mean.
I have not done any changes.
14 Jul 2015 12:57 #2 by babynus
Thkis generally applies when some javascript formatting fails.
Could you please check for errors in browser console and report it here ?
14 Jul 2015 13:50 #3 by iconic
How do I check for errors in browser console?
14 Jul 2015 14:21 #4 by babynus
As this question occurs very often, I added some hint :
www.projeqtor.org/en/forum/9-tips-tricks...ore-submitting-issue
14 Jul 2015 14:39 #5 by iconic
I have done everything on the link you provided. I even logged out and closed the actual browser that I use, which is Windows Google Chrome. The problem still occurs.
I had a look at any errors and I found the following ...
1) Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user's experience. For more help, check xhr.spec.whatwg.org/.
dojo.js:15
2) 'KeyboardEvent.keyLocation' is deprecated. Please use 'KeyboardEvent.location' instead.
dojo.js:15
3) Uncaught ReferenceError: paramCurrencyPosition is not defined
projeqtorFormatter.js:228
14 Jul 2015 14:47 #6 by babynus
3) is the source of the issue.
You can try :
=> goto gobal parameters, check for parameter "currency position" (should be before or after), and save.
(save even if you changed nothing)
Disconnect, reconnect and try again
=> if previous trick did not work, remove all "cost" data in the list.
This should be a good workaround
=> I'll propose a patch (ticket #1764 recorded)
