ProjeQtOr free project management software - [SOLVED] Text not being displayed on List Element Box - Page 2 - ProjeQtOr
14 Jul 2015 15:01 #7 by babynus
Issue fixed.
Will be deployed on V5.0.3.
As I guess you not actually use V5, here is the fix :
if /view/js/projeqtorFormatter.php, in function "costFormatter" (about line 228 on your version, line 265 in V5.0.2),
replace "paramCurrency" with "top.paramCurrency",
replace "paramCurrencyPosition" with "top.paramCurrencyPosition"
Disconnect, clean browser cache and all should work fine now.
14 Jul 2015 18:48 #8 by iconic
I have tried option 1) parameter "currency position".
This was already showing as before, just for the sake of it, I changed it to after. Saved, disconnected and reconnected and problem still occured.
I do not understand what you mean by remove all "cost" data in the list. I have 10s of thousands of dollars added. I can't change this as it will ruin the total costings of each project and activity. This would create more of an issue, then fix the problem.
Thank you for proposing an update.
14 Jul 2015 18:50 #9 by babynus
Proposale is not to delete cost :silly:
Just to unselect the cost columns in the list (through the column selector in the list)
14 Jul 2015 18:57 #10 by iconic
I misunderstood what you meant.
I used fix you provided and worked perfectly. I am about to upgrade to version 5.03 very soon. Always worried when upgrading about losing data. So I am having my IT team doing this for me. Thank you again for your prompt support.
14 Jul 2015 19:29 #11 by babynus
You should not be frightened about upgrades (even if it is always advised to backup prior to migrate).
Moreover for patch, as they very rarely bring data updates, and if they do, it is always in a way to fix things.
Time to create page: 0.081 seconds
