ProjeQtOr free project management software - Problems with new install of Projeqtor 5.0.1. - Page 2 - ProjeQtOr
11 Jul 2015 12:16 #7 by babynus
The STRACE file for all the processes of HTTPD and POSTGRESQL for this is attached
No attached file :(
Could you also check browser console for errors ?
11 Jul 2015 15:33 #8 by VERNCon
Well, not sure what happened to them....
I have worked around it as a temporary measure, to try and get the DB up, but will need to sort out why it will not connect through 127.0.0.2, or shut it down and revert to original before Monday AM.....
I have changed the server IP to 127.0.0.1 and now it connects, as well as trying to configure from the "normal" config page.
BUT..... no matter what name I give the logs file name. it keeps throwing up an error:
incorrect value for 'Log file name', cannot write to such a file
or
incorrect value for 'Log file name', does not include a valid directory name
WHAT is a valid file name, as it certainly does not like the default with the full path added.....
Cheers,
Verncon.
11 Jul 2015 15:36 #9 by VERNCon
No attached file :(
Browser console has been wiped ,,,,, sorry.
11 Jul 2015 16:10 #10 by babynus
you can define any valid file name for log file, absolute or relative
default is '../files/logs/projeqtor_${date}.log' (relative way)
you can use absolute way such as '/var/logs/projeqtor/projeqtor_${date}.log'
(adding {date} will generate 1 file per day)
Important : the folder must exist (it is not created dynamically) and php user must have write rights in the folder.
11 Jul 2015 17:52 #11 by VERNCon
OK, finally got it to accept the parameters (chown apache:apache, chmod 777 and Selinux Permissive), but now It says "invalid login parameters"
Have tried various combinations of admin, projeqtor and my DB login, none will let me in - any clues?
Cheers,
Verncon.
11 Jul 2015 19:35 #12 by VERNCon
I have played around with permissions, etc, and at least on my Fedora 22 server the minimum is CHMOD 755, the projeqtor directory & sub-directories owned by the php user, with those directories and associated files set to SELINUX context httpd_sys_rw_content_t
Moving on tho the next problem, I cannot login.
In the documentation it is given as "admin" and "admin", but that appears to not work.
I have created a new user for the database, with a valid password, and that does not work either.
When searching the forum archives I cannot find any responses to people's questions as to how to access the system once it is configured.
I would appreciate your assistance on this.
Cheers,
Verncon.
