ProjeQtOr free project management software - Problems with new install of Projeqtor 5.0.1. - Page 3 - ProjeQtOr
11 Jul 2015 20:36 #13 by VERNCon
OK, DONE!!!
I shall leave you in peace and quiet for a while now, I finally figured out from other comments on the initial login issue what had to be done to gain access.
Many thanks for your assistance.
Cheers,
Verncon.
27 Jul 2015 10:55 - 27 Jul 2015 10:59 #14 by Mams
I encounter the same problem as you.
Installing CentOS 6 projeqtor under x86_64 and postgresql 9.4 does not. I took the parameters in configuration in the "main view" GUI, and the system hangs. The log file is empty.
How have you solved the problem?
Can you help me?
Thanks for your answer.
Last edit: 27 Jul 2015 10:59 by Mams.
27 Jul 2015 11:10 #15 by VERNCon
I had a couple of issues, here are the points that I found not so clear:
1. All of the external files (logs, cofig, etc) MUST be relative to the projeqtor install base, i..e if you have installed projeqtor in /var/www/html/, then all the files must be in a directory under the projector directory.
2. When you get the login screen and it returns "invalid password" or something similar, you need to go into the DATABASE, to Table "Parameter", find "dbVersion" and change it to "V5.0.x" (without " ", and x being the last version digit, i.e. 2 or whatever you have loaded).
Cheers.
The following user(s) said Thank You: clabybite
27 Jul 2015 11:45 #16 by babynus
No, this is not mandatory, and is a security leak.
Config, documents directory, attachements directory and log files should be out of web reach.
For instance, with
- web as /var/www,
- projector on /war/www/projeqtor,
I usualy
- logs in /var/wwwFiles/logs
- attachments in /var/wwwFiles/attach
- documents in /var/wwwFiles/documents
- config in /var/wwwFiles/config/parameters.php
But you must ensure that php user has write rights to there folders.
This should ne be mandatory.
In most cases, when login fails despite correct login/password, cleaning browser cache and deleting cookies should be enough to fix.
27 Jul 2015 12:56 #17 by VERNCon
My apologies for the confusion - I was not able to get my system working any other way . I will try to change it to use the settings you outline in your post.
I had no success in getting mine to log in with browser cache and cookie clearance, and the majority of other similar posts on this subject it was said that the database version needed to che checked/changed in the parameters table.
Cheers.
27 Jul 2015 13:21 #18 by babynus
Checked : yes, it is a good hint for me to know wehter install or migration was successfull
Updated : it can be a workaround, but should only be considered at last chance. Any other solution should be tested first (direct update of database is always a bad idea)
