ProjeQtOr free project management software - I can't loggin in fresh v.5.0 install - Page 2 - ProjeQtOr
19 Jun 2015 14:16 #7 by babynus
Strange, it seems spl_autoload_register() fails on your system.
Which version of PHP are you using ? (PHP 5.2 or over is required)
19 Jun 2015 15:54 #8 by clisboa
Really strange.
PHP Version is 5.3.1
19 Jun 2015 17:31 #9 by babynus
1) Try attached file : unzip it in /tool, to replace existing projeqtor.php
I don't think it will work, but it will avoied any side effect of other PHP applications running on your server.
It is to be sure.
2) Please detail exactly how, when and where you get the error message.
Some print screen may help.
19 Jun 2015 17:50 #10 by clisboa
Hi.
I download and install file as you toll me and restart apache, deleted session files in tmp.
start_page.jpg show initial access control page.
user_pass.jpg show access control with user and password set
I attached the log file too.
Regards.
19 Jun 2015 18:07 #11 by babynus
Which version of xampplite are you using ?
I wonder if something may be missing in the "lite" version that could explain issue.
I will try to test with your version of xampplite.
Could you on your side try with another xAMP stack (easy PHP, or other) ?
19 Jun 2015 18:57 #12 by clisboa
I have XAMPP Lite v.1.7.3 with PHP 5.3.1
In my PC I have XAMPP 5.6.3 with PHP 5.6.3 but when I try to update from v.4.4.2 it fails. Then I try a fresh install in XAMPP Lite v.1.7.3 with minimal requirements OK, I think....
Regards.
