ProjeQtOr free project management software - I can't loggin in fresh v.5.0 install - Page 3 - ProjeQtOr
19 Jun 2015 19:21 #13 by babynus
I have XAMPP Lite v.1.7.3 with PHP 5.3.1
Thanks for this information, I'll try it.
when I try to update from v.4.4.2 it fails
What happens exacly ? What is the issue / errors logged ?
19 Jun 2015 19:26 #14 by babynus
I installed XAMPP lite 1.7.3.
Installed new V5.0.0 (downloaded form site to be sure to get exactly same as yours).
Got to localhost/projeqtor : arrived at configuration screen
Changed only default password (to null), saved : OK, database create OK
Clik on continue : OK to login screen.
Enter admin/admin : Database correctly UPDATED to V.5.0.0
Log in as Admin : OK
So all worked fine for me.
I have no clue about what could happen in your case...
I must be linked to your configuration.
Maybe some Antivirus or Firewall blocking something.
Try and disable all to test....
25 Jun 2015 13:39 #15 by clisboa
Hi!
Now I'm try with v.5.0.1 and have this error message in log file.... :(
2015-06-25 08:33:05.014 ===== TRACE =====
2015-06-25 08:33:05.015 ===== TRACE ===== =====================================
2015-06-25 08:33:05.016 ===== TRACE =====
2015-06-25 08:33:05.016 ===== TRACE ===== DataBase actual Version = V5.0.0
2015-06-25 08:33:05.016 ===== TRACE ===== ProjeQtOr actual Version = V5.0.1
2015-06-25 08:33:05.017 ===== TRACE =====
2015-06-25 08:33:05.652 ===== TRACE ===== =====================================
2015-06-25 08:33:05.653 ===== TRACE ===== DATABASE UPDATE COMPLETED TO VERSION V5.0.1
2015-06-25 08:33:05.654 ===== TRACE ===== =====================================
2015-06-25 08:33:10.709 ===== TRACE ===== NEW CONNECTED USER 'admin'
2015-06-25 08:33:10.906 ***** ERROR ***** ERROR *****
2015-06-25 08:33:10.906 ***** ERROR ***** on file 'D:\xampplite\htdocs\projeqtor\tool\projeqtor.php' at line (125)
2015-06-25 08:33:10.907 ***** ERROR ***** cause = main() [<a href='function.main'>function.main</a>]: The script tried to execute a method or access a property of an incomplete object. Please ensure that the class definition &quot;User&quot; of the object you are trying to operate on was loaded _before_ unserialize() gets called or provide a __autoload() function to load the class definition
Regards.
25 Jun 2015 18:51 #16 by clisboa
I installed XAMPP v.1.8.2 then installed projeqtor v.5.0.1 and now is working.
Thanks for all!!
14 Jul 2015 15:44 - 14 Jul 2015 15:49 #17 by dahan
I have the same issue... unable to login after fresh install... v5.0
Here is the server I am using: dahan.ws/phpinfo.php
thanks in advance.
clisboa wrote: Hi!
Regards.
Last edit: 14 Jul 2015 15:49 by dahan.
14 Jul 2015 15:52 #18 by babynus
Hi
First check session.auto_start parameter in php.ini : it must be off for projeqtor.
Then, deploy v5.0.2 as it fixes this issue (at least point out exact error)
Time to create page: 0.077 seconds
