ProjeQtOr free project management software - Impossible to connect after the installation - Page 2 - ProjeQtOr
19 Jan 2015 12:53 #7 by MBX
babynus wrote: Which version did you install ?
On which on ?
What is version in /tool/projeqtor.php ? ($version, line 35) I found this in projeqtor.php :"$version="V4.2.2"];
What is version in database ? (value of column parameterValue in table parameter, line with parameterCode='dbVersion') I found this for the DB version : dbVersion V0.3.0
Thanks for your help
19 Jan 2015 13:01 #8 by babynus
You really have a big issue on your Database.
Setup was really uncomplete, and database schema does not fit code version.
For information you should have same version on projeqtor.php and database.
What is very strange is that database is in version 0.3.0.
It means only the first update script was run. But if you had had an error, database version should not have been set at all (it is the last ting that is done) and it is set from code version.
All appears as if you installed old V0.3.0 and then try to run V4.2.2 code... :silly:
Best for you is to start from scratch : delete your database and try again.
This time, ensure you have all required scripts in /db folder, with correct access rights.
Regards.
19 Jan 2015 13:13 #9 by MBX
Ok, thanks : I will restard from scratch.
19 Jan 2015 13:23 #10 by babynus
Other hints :
- before starting reinstall, clean your log file (delete it) and post whole file directly in forum for analysis
- check that your php is not is safe mode : it would prevent set_time_limit from working and could lead to unexpected end.
- try and install latest stable release : V4.5.4
19 Jan 2015 13:26 #11 by MBX
Ok, I've taken the last version.
Where is the log file (in which directory) please ?
19 Jan 2015 13:42 #12 by babynus
in /files/logs (by default).
This can be changed on setup, but for first install keep it there (you'll be able to move it afterwards).
