ProjeQtOr free project management software - Impossible to connect after the installation - Page 3 - ProjeQtOr
19 Jan 2015 13:42 #13 by MBX
I've re-installed and got the same problem : "Invalid login parameters" with login / pwd admin / admin.
The version in projeqtor.php is 4.5.4.
There are 128 tables in the db, and the db version in table parameter / dbversion is 3.0.
19 Jan 2015 13:45 - 19 Jan 2015 13:47 #14 by MBX
Here's the log file of the last installation (4.5.4)
Last edit: 19 Jan 2015 13:47 by MBX.
19 Jan 2015 14:31 #15 by babynus
I got it thnaks ot the log file :woohoo:
It appears you are using IIS as PHP serveur.
And there seems to be an issue with IIS : $_SERVER is not set.
I will investigate on this side (Ticket #1641 recorded)
On your side, database upgrade seems correct, except for db version.
Try and update version in database (to fit code version) and try again.
19 Jan 2015 15:04 #16 by MBX
To update version in database, you mean I have to fit with 4.5.4 ?
19 Jan 2015 15:31 #17 by babynus
Yes.
Update corresponding line in table parameter
19 Jan 2015 16:45 #18 by MBX
THANKS ! After I updated the dB version in the database, the login admin was accepted.
