ProjeQtOr free project management software - How to display two fields on same line ? - ProjeQtOr
13 Jun 2014 15:32 - 13 Jun 2014 15:47 #1 by Jean-Luc
I added for clients a Taxnum field as varchar(32), for VAT Nr.
How to do to display it near the field 'tax' on the same line ?
Last edit: 13 Jun 2014 15:47 by Jean-Luc.
13 Jun 2014 16:16 #2 by babynus
add "nobr" attribute on previous field.
13 Jun 2014 16:31 #3 by Jean-Luc
Added
private static $_fieldsAttributes=array("tax"=>"nobr"
and
protected function getStaticFieldsAttributes() {
    return self::$_fieldsAttributes;
in model/Client.php (no $_fieldsAttributes was defined in this module, so I took example on model/Project.php)
… but don’t works !
I probably missed something, but what ?
13 Jun 2014 17:05 #4 by babynus
You did it right.
I don't know why it dow not work.
Possibly one of the two fields is too big.
You can try to add attribute "smallWidth" or "mediumWidth"
13 Jun 2014 17:24 - 13 Jun 2014 17:39 #5 by Jean-Luc
Indeed, field size problem. Reduced "taxnum" from 32 to 24 bytes, and this field comes besides "tax". :)
… but without its label… :pinch:
Is another parameter requested ? :(
Note: only field size reduction works OK. "smallWidth" permits 32 bytes, but strongly reduces (too) the input/display field.
Edit : "mediumWidth" gives a better width.
Last edit: 13 Jun 2014 17:39 by Jean-Luc.
13 Jun 2014 17:45 #6 by babynus
No.
nobr hides label of second field.
In common design, if fileds are on same line, then label if for both.
