ProjeQtOr free project management software - How to display two fields on same line ? - Page 2 - ProjeQtOr
13 Jun 2014 17:52 #7 by Jean-Luc
Too bad. So I have to leave on separate lines…
19 Jun 2014 12:54 #8 by Jean-Luc
Banynus, you didn’t said everything… :lol:
It is possible to have several fields on same line with their labels, by using arrays.
Seen p.e. on projectPlanningElement. I’ll will try in the future. ;)
19 Jun 2014 13:52 - 19 Jun 2014 13:53 #9 by babynus
You can use array (see exemple in ActivityPlanningElement.php).
But then you'l have something like
"Label 1" "Label 2"
"main label" Fld 1 Fld2
I guess what you expect is :
"label 1" : fld1 "label 2" : fld2
But this is not possible.
All you can do is change label to get :
"label 1 / label 2" : Fld1 Fld2
Last edit: 19 Jun 2014 13:53 by babynus.
19 Jun 2014 14:03 #10 by Jean-Luc
In projectPlanningElement, there is specifics labels for fields in the last column. ;)
No problem, I will try myself. :)
