ProjeQtOr free project management software - [SOLVED] Activities deleted - Page 2 - ProjeQtOr
13 May 2014 20:13 #7 by babynus
Replied by babynus on topic Activities deleted
My mistake : you must also define $logLevel="3";
to activate debug level.
13 May 2014 21:00 #8 by DPo
Replied by DPo on topic Activities deleted
Ok, it worked better ;-)
log file sent.
14 May 2014 14:56 #9 by babynus
Log helped to find a hint.
It seems the program tries to delete twice the same Activity.
I don't know how this can happen and could not reproduce.
But when trying to delete Activity already deleted, it comes to cascading delete activities with idActivity = null. Which leads to deletion of most activities.
The workaround is to update code in /model/persistence/SqlElement.php, add one line after line 895, so it looks this way :
private function deleteSqlElement() {
		if (! $this->id or $this->id<0 ) {return;}
		$class = get_class($this);
Could you try it and confirm it fixes the issue ?
14 May 2014 21:10 #10 by DPo
Modification done, it fixed the issue. (controled twice)
Thank you very much ! and Please continue with this great work ! :)
19 May 2014 21:13 #11 by DPo
Hi babynus,
any chance to have it integrated the next release ?
19 May 2014 22:47 #12 by babynus
The fix will of course be integreted in next release.
