ProjeQtOr free project management software - [SOLVED] Activities deleted - ProjeQtOr
12 May 2014 18:21 - 13 May 2014 08:53 #1 by DPo
Activities deleted was created by DPo
A BIG issue I faced today :
While deleting a project with 9 activities attached, Projeqtor asked the confirmation to delete the 9 activities related (ok, normal behavior) but it deleted also the whole set of activities whatever the project except 1 activity (why this one in particular !?).
here below the structure of the project to delete
Done it twice to control (with a backup), each time the same results with the deletation.
Browser : Firefox 29.0.1
Version : ProjeQtOr V4.2.3, windows server with mysql
Last edit: 13 May 2014 08:53 by DPo.
13 May 2014 10:35 #2 by babynus
Replied by babynus on topic Activities deleted
Sorry, I don't understand exactly the issue described :
Do you mean it deleted activities that sould not have been deleted ?
(it is not clear in the screenshots)
except 1 activity
Is it an activity that should have been deleted ?
Could you try to delete it manualy : do you get any message that could explain the behavior ?
Could you check log file for errors are report them here ?
13 May 2014 11:29 #3 by DPo
Replied by DPo on topic Activities deleted
That's it,
expected : 9 activities linked to the project to be deleted
Issue : ALL the activites of the database deleted (more than 300), whatever the project, except 1 activity.
sorry for the screen shots, I wanted to show the original structure of the project / activities to be deleted.
No, the one activity remaining was out of the project deleted,
In both my tries, it was the same activity remaining, though the databases were not exacly the same (the backup had less records)
No error risen in the log file at both tries. only the trace of logging.
The first time, The screen "freezed" after the confirmation of deleting the project and activities. I closed ff and relaunched and discover the results of deletation (only 1 activity remaining)
after restoring the backup, I chose the same project to delete and after few seconds of work the screen show back the project list but the database contains only one activiy left, the same as the first time.
13 May 2014 11:52 #4 by babynus
Very Strange : I cannot reproduce :(
Do you have a structure of projects ?
(deleting project will delete sub-projects and activities of sub-projects).
13 May 2014 11:54 #5 by babynus
To help debug; could you try :
- go to the project you wish to delete.
- update parameters.php file to set $debugQuery=true;
- delete project
- retrieve log file and send it to This email address is being protected from spambots. You need JavaScript enabled to view it.
13 May 2014 18:39 #6 by DPo
Sorry,
In the file : projeqtor\files\config\parameters.php
I added the line : "$debugQuery = true;" but nothing appeared in the log file when I delete the project,
:huh: I tried also "$debugQuery = 'true';" without success either.
Only the --TRACE-- are written in log file.
Time to create page: 0.072 seconds
