ProjeQtOr free project management software - CentOS installation problem - Page 2 - ProjeQtOr
30 Apr 2014 23:52 #7 by rsaint1927
babynus wrote: With rights on 777, there shouldn't be any issue to store parameter.php file.
Anyway, what you can try a chown to give onwenrship to php user (user launching PHP).
babynus, it looks like a SELINUX issue. One has to add specific permission to SELINUX so that the PHP can access the filesystem outside /var/www/html.
I'm not planning to change much the parameters.php file. If needed, will edit it by hand. This way, won't have to mess around with SELINUX.
01 May 2014 00:06 #8 by babynus
Replied by babynus on topic CentOS installation problem
Glad to know you foound source of the issue.
Just to know, parameters.php file will not have to be changed after install.
All parameters that can be changed afterwards are stored in database...
