ProjeQtOr free project management software - CentOS installation problem - ProjeQtOr
27 Dec 2013 10:58 #1 by soji
I installed a new CentOS server.
Here is my configurations:
projeqtor v4.0.6
centos 6.5 64bit
httpd 2.2
php 5.3
mysql 5.1
I don't have a taskbar for create a new item (see in attachment). I reinstall several times (x5) and I have the same error...
When I installed on Debian server I don't have any problem.
Can you help me please.
Thanks in advance..
27 Dec 2013 13:21 #2 by babynus
Replied by babynus on topic CentOS installation problem
It is probably an missing php module.
First check for requirement, as defined in the README file :
PHP configuration advised :
register_globals = Off ; securite advise
magic_quotes_gpc = off ; security advise
max_input_vars = 4000 ; must be > 2000 for real work allocation screen
max_execution_time = 30 ; minimum advised
memory_limit = 512M ; minimum advised for PDF generation
file_uploads = On ; to allow attachements and documents management
PHP extensions required :
gd => for reports graphs
imap ==> to retrieve mails to insert replay as notes
mbstring => mandatory. for UTF-8 compatibility
mysql => for default MySql database
mysqli => for default MySql database
openssl => to send mails if smtp access is authentified (with user / password)
pdo_mysql => for default MySql database
pdo_pqsql => if database is PostgreSql
pgsql => if database is PostgreSql
php-xml => for xml parsing
You likely have some error in the log file.
Please report it here.
27 Dec 2013 15:29 #3 by soji
Replied by soji on topic CentOS installation problem
In effect, php-xml module was missing. The problem is resolved.
However I checked with the readme.txt file, It's not rated to install this module.
Can you add the module in readme file.
Thanks a lot babynus
27 Dec 2013 17:01 #4 by babynus
requirement is added in readme file in V4.1
10 Apr 2014 17:54 #5 by rsaint1927
Hello to all,
I've just installed a production server with the following config:
OS: CentOS release 6.5 (Final) x86_64
Web Server: httpd-2.2.15
MySQL: MySQL 5.6.17
PHP: PHP 5.3.3
ProjeQtOr: V4.2.3
I've detected that the parameters.php file can't be written.
We tried several locations, with "777" permissions, and nothing happens.
The last place I've tried is the folder where we have ProjeQtOr's log files, that are written with success, replicating the permissions.
The parameter location file is pointing to the right location.
I do'nt have any error on log's files, no matter the "log level" I set.
Can you please advice?
Thanks in advance.
11 Apr 2014 14:49 #6 by babynus
With rights on 777, there shouldn't be any issue to store parameter.php file.
Anyway, what you can try a chown to give onwenrship to php user (user launching PHP).
The following user(s) said Thank You: rsaint1927
