ProjeQtOr free project management software - Gantt chart Incompatibility with Firefox 24 and 25 - ProjeQtOr
30 Oct 2013 15:24 - 30 Oct 2013 15:25 #1 by ekolossov
Gantt chart is not compatible with Firefox 24 and 25 - see enclosed screenshot.
I believe this problem happened some time ago and now again.
Evgueni
Last edit: 30 Oct 2013 15:25 by ekolossov.
30 Oct 2013 16:13 #2 by babynus
Hi
I could not reproduce.
Gantt is working fine on my side.
Firefox V25 gives exactly same (and correct) display as V23.
Did you reproduce on several work stations ?
Is it linked to some specific display ? For instance, if you limit display to few projects, does the issue still occur ?
What is sure is that issue is due to unexpected line break betwin drgger icon and Class icons. I'll investigate.
Ticket #1215 recorded.
30 Oct 2013 16:16 - 30 Oct 2013 16:18 #3 by ekolossov
Happening not on all but on some projects - very strange. Probably some special characters somewhere.
Works Ok in IE
Last edit: 30 Oct 2013 16:18 by ekolossov.
30 Oct 2013 16:28 #4 by babynus
If you have a hint about how to reproduce (what special caracter or other potential source of issue) please let me know.
The knowledge of the source will help the fixing.
30 Oct 2013 16:42 #5 by ekolossov
Sure will do if I will find it. Checked all the projects - happening only with one...
Any suggestions how to localize the problem?
30 Oct 2013 17:27 #6 by babynus
I you identified the project, try to find any difference or specificity :
- long name
- special cars
- length of data in other columns that could force a line break
