ProjeQtOr free project management software - Gantt chart Incompatibility with Firefox 24 and 25 - Page 2 - ProjeQtOr
30 Oct 2013 17:39 #7 by babynus
I got it :woohoo:
This happens when the value in one of the columns is largest than the column itself.
To reproduce, I just entered 999999,99 days in the validated work field.
This produces the issue on FireFox and Chrome.
Surprisingly, IE display is still correct. :silly:
In fact, it is because IE font size is a bit smaller than other browsers.
Entering 9999999,99 days in the validated work field also displays the issue on IE :P
I'll look for a fix.
30 Oct 2013 19:48 - 30 Oct 2013 19:49 #8 by babynus
I think I have a workaround.
Try code in attached file :
- unzip and copy it into /view/js to replace existing one
- clean web cache
- test
Last edit: 30 Oct 2013 19:49 by babynus.
The following user(s) said Thank You: ekolossov
31 Oct 2013 12:30 #9 by ekolossov
Thank you very much - it works!
