ProjeQtOr free project management software - error on recalculate project - ProjeQtOr
31 Jul 2013 16:57 #1 by ekolossov
Please see attachment
31 Jul 2013 17:49 #2 by babynus
It seems clear : Out of Memory.
Maybe you tried to plan too many activities in one step.
=> try planning project by project or allocate more memory to PHP server.
01 Aug 2013 13:32 - 01 Aug 2013 13:59 #3 by ekolossov
more memory allocation not help at all.
some more errors from log:
2013-08-01 11:17:10 ***** ERROR ***** Exception-[42000] SQLSTATE[42000]: Syntax error or access violation: 1064 You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ')' at line 1
2013-08-01 11:17:10 ***** ERROR ***** For query : select * from dependency where successorId in (0,)
2013-08-01 11:17:10 ***** ERROR ***** Strack trace :
2013-08-01 11:17:10 ***** ERROR ***** #0 Sql->query called at [/var/www/localhost/htdocs/projectorria/model/persistence/SqlElement.php:1268]
2013-08-01 11:17:10 ***** ERROR ***** #1 SqlElement->getSqlElementsFromCriteria called at [/var/www/localhost/htdocs/projectorria/model/PlanningElement.php:854]
2013-08-01 11:17:10 ***** ERROR ***** #2 PlanningElement->initializeFullList called at [/var/www/localhost/htdocs/projectorria/model/PlannedWork.php:135]
2013-08-01 11:17:10 ***** ERROR ***** #3 PlannedWork->plan called at [/var/www/localhost/htdocs/projectorria/tool/plan.php:18]
2013-08-01 11:17:16 ***** ERROR ***** Exception-[42000] SQLSTATE[42000]: Syntax error or access violation: 1064 You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ')' at line 1
2013-08-01 11:17:16 ***** ERROR ***** For query : select * from dependency where successorId in (0,)
2013-08-01 11:17:16 ***** ERROR ***** Strack trace :
2013-08-01 11:17:16 ***** ERROR ***** #0 Sql->query called at [/var/www/localhost/htdocs/projectorria/model/persistence/SqlElement.php:1268]
2013-08-01 11:17:16 ***** ERROR ***** #1 SqlElement->getSqlElementsFromCriteria called at [/var/www/localhost/htdocs/projectorria/model/PlanningElement.php:854]
2013-08-01 11:17:16 ***** ERROR ***** #2 PlanningElement->initializeFullList called at [/var/www/localhost/htdocs/projectorria/model/PlannedWork.php:135]
2013-08-01 11:17:16 ***** ERROR ***** #3 PlannedWork->plan called at [/var/www/localhost/htdocs/projectorria/tool/plan.php:18]
and additional screenshot
Last edit: 01 Aug 2013 13:59 by ekolossov. Reason: additional information
01 Aug 2013 14:18 #4 by babynus
Strange issue.
It seems you are planning no activity...
1) can you check table planningelement : check that idProject is never 0, and that refType and refId are always set (not null)
2) can you try this patch :
in /model/PlanningElement.php, replace line 851 with :
$crit='successorId in (0' . (($idList and count($idList)>0)?',' . implode(',',$idList):'') . ')';
01 Aug 2013 14:37 #5 by ekolossov
Looking like we found an issue and fixed it. we have moved group of tasks from one project to another and this have caused the problem
01 Aug 2013 14:59 #6 by babynus
Sorry, I don't understand your message.
Did the action to move the tasks "create" or "fix" the issue ?
