ProjeQtOr free project management software - error on recalculate project - Page 2 - ProjeQtOr
01 Aug 2013 15:02 #7 by ekolossov
It created an issue. When moved back it fixed an issue. After these tasks been moved one by one everything is ok. Looking like it is possible to move group of tasks under one common task (one level) to another project but if you have more then one level - it will create a problem we have seen...
01 Aug 2013 16:40 #8 by babynus
thnaks for the description.
I recorded Ticket #1154, and will try and reproduce thanks to your description of tests case.
thanks for reporting.
01 Aug 2013 23:20 #9 by babynus
After first analysis, it seems to be some dependency loop issue.
When moving group of activities, it may happen that control of dependency loop does not correctly trigger error on sub-activity, to forbid the move.
So you may get a dependency loop that will generate the error you're facing when calculating planning.
I'll investigate to :
- avoid dependency loop
- detect these loop on planning calculation to avoid error message
