ProjeQtOr free project management software - [CLOSED] Migration problem from 3.2.2 to 3.3.1 - ProjeQtOr
02 May 2013 09:59 - 04 Jun 2013 11:48 #1 by Iaurkano
Hi babynus,
i tried to migrate my projectoria from 3.2.2 to 3.3.1 and i met a planning issue.
So, it seems i lost all start date, in fact when i open the planning for a project all tasks and milestone start at the "start displayed date" but finish normally.
in addition i saw in the planning that the vertical lines are not displayed any more, is it normal ?
I had to go back to 3.2.2 because of this issue.
Thank's for your help.
Last edit: 04 Jun 2013 11:48 by Iaurkano. Reason: close topic
02 May 2013 11:49 #2 by babynus
It is exactly same behavior in V3.3 and V3.2.
You must have some issue about images. New format uses images to display lines. Maybe some cache issue possibly browser cache, but more probably server cache.
02 May 2013 13:35 #3 by Iaurkano
re,
i cleared browser cache, and restarted apache, php and mysql service. the problem still present.
i used firefox 18 or Ie 8.
with V3.3.2 :
and a click on an activity does not display it.
using 3.2.2 :
works fine.
One idea.
02 May 2013 19:44 #4 by babynus
I cannot reproduce :
- FF 20 on Win XP : OK
- IE8 on Win XP : OK
- Chrome 26 on Win XP : OK
- FF 20 on Win 7 : OK
- IE9 on Win 7 : OK
- Chrome 26 on Win 7 : OK
Could you try on Demo instance ? Do you produce the issue ?
On which OS do you produce issue ?
Does it occur on several client workstation or only one ?
Do you have the opportunity to test with Chrome or FF20 ?
03 May 2013 08:40 #5 by Iaurkano
hi,
so i performed test, on FF20 the problem still exist.
but not in demo database whatever the browser.
So it seems coming from the server size. for information the server is now on XP using apache 2.2.22, PHP 5.3.13 and MySQL 5.0.88.
i m going to try with 3.3.2 version as soon as possible.
regards.
03 May 2013 09:31 #6 by babynus
Yes, it is likely to be a server side issue.
But V3.3.2 will not bring any better from V3.3.1.
What you can try is deploy a brand new set-up in V3.3.2.
