ProjeQtOr free project management software - [CLOSED] Migration problem from 3.2.2 to 3.3.1 - Page 2 - ProjeQtOr
06 May 2013 09:34 #7 by Iaurkano
hi babynus,
i deployed this morning a new Projectorria 3.3.1 from scratch on my server, i added a project an activity and go to planning, and .... i met the same issue.
so the source of the problem seems to be the server configuration.
did you used specific php extension for planning in 3.3.X ? another idea ?
Best regards.
06 May 2013 13:45 #8 by babynus
No, nothing is new on server side...
another idea ?
Only possibility I can think of is that your server does not provide correct css or js files.
06 May 2013 13:48 - 06 May 2013 14:04 #9 by Iaurkano
babynus wrote: Only possibility I can think of is that your server does not provide correct css or js files.
Sorry i don't understand.
could you explain ?
and why on the same server the 3.2.2 work fine and not the 3.3.1 !!!!
Last edit: 06 May 2013 14:04 by Iaurkano.
06 May 2013 15:35 #10 by babynus
Gantt display has completely changed on V3.3.
New version uses new CSS styles that are very important to have correct display.
If you work with old CSS file, display will be wrong.
But I don't really nderstand how you can get old CSS with new version.
Perhaps some apache static files mess, as they have semae name ...
What you can do on V3.3 is try to display with V3.2 style : just add in parameters.php [code type=php-brief]$ganttPlanningOldStyle=true;[/code]
06 May 2013 17:42 - 06 May 2013 17:43 #11 by Iaurkano
babynus wrote: New version uses new CSS styles that are very important to have correct display.
i tried your $ganttPlanningOldStyle=true; but doesn't work.
i look in firefox debugger, and it seems th jsgantt.css file is the old one, the one packaged with 3.2.2 but not in 3.3.1.
So the next step : to find why Apache is using the wrong css file.
Last edit: 06 May 2013 17:43 by Iaurkano.
04 Jun 2013 11:34 #12 by Iaurkano
hi all,
we found the root cause and the solution of this issue.
in fact, it came from "compatibility parameters" in Internet explorer, why the problems was present in Firefox stays a mystery.
so, my IE 8 was configured to be in compatibility mode for all intranet site. that's why on Projectorria's demo, the display was good.
So, today, my projectorria is on production server, the compatibility parameters are set to "no" for all sites (internet and intranet) and everything is OK under IE and Firefox on version 3.3.2.
Thank's everybody.
see you.
