ProjeQtOr free project management software - Problem with Project list - ProjeQtOr
06 Sep 2012 12:18 #1 by jmmbb
for some users, there is a problem in the problem list.
All projects are visible PROJECT screen (see attach 1), activities are visibles too, but some projects doesn't appears in TODAY screen and combolist (see attach 2).
Jean-Marie
06 Sep 2012 13:13 #2 by babynus
hi,
Highlighted project is of "Modèle" type.
If this is translation of "Template" type, with code = "TMP", it is normal.
Template projects are not displayed on the Today screen.
They are visible to users with "Project update" right (typically project leaders), just to be copies.
Try and change the project type, you'll see the difference.
Also have a look at the user manual; it contains some interesting things. :whistle:
RTFM :evil:
06 Sep 2012 13:35 #3 by jmmbb
Replied by jmmbb on topic Re: Problem with Project list
Highlighted project is not signifiant. I Speak about project 138 that is not displayed in TODAY screen or combo.
Also, even when changing project type, it doesn't appear anymore (I've refreshed the page too).
06 Sep 2012 13:41 #4 by babynus
Check rights to the projects : if visibility rights are set to "own projects", it will appear only if user is affected to the project.
Also consider that if project has been newly created or affected to, if will correcly appear only after new connection.
06 Sep 2012 14:36 #5 by jmmbb
Thanks for reactivity !
I've just created a new project for test, it appear in project list and combo, but project 138 doesn't appear anymore...
CDP_TEST is ressource and contact on this project (see attachment).
This is an example, i have many occurrence of this problem...
Actualy, there are 43 "reals" projects in the database, and at least 4 users report the problem.
06 Sep 2012 14:51 #6 by babynus
Just go to your project and save it, without any change.
It appears that if project has been copied, it must be saved so that status is correctly defined.
By defaut copied items have no status, and it may lead to visibility issues. An improvement is planned to introduce new status for initialy copied items to avoid this issue.
