ProjeQtOr free project management software - Problem with Project list - Page 2 - ProjeQtOr
06 Sep 2012 15:12 #7 by jmmbb
Replied by jmmbb on topic Re: Problem with Project list
No effect.
Project 138 was created from scratch. however, i try to change description and save the project... still invisible for cdp_test (and the real user who work on it !).
06 Sep 2012 15:42 #8 by babynus
Can you show / post printscreen of :
- project 138 detail
- user CDP_TEST detail
- access modes screen
- access mode to data screen
06 Sep 2012 16:10 - 06 Sep 2012 16:28 #9 by jmmbb
Here are the details :
Attach 1 : project 138 details
Attach 2 : User CDP_TEST details
Attach 3 : access modes screen
Attach 4 : access mode to data screen
EDIT : I try to create a new project from CDP_TEST profile, it works fine, but Project 138 still invisible...
Last edit: 06 Sep 2012 16:28 by jmmbb. Reason: Test creating a new project
06 Sep 2012 19:57 #10 by babynus
I cannot see any issue.
All seems correctly configured.
Did the user CDP_TEST explicitly disconnect and reconnect ?
06 Sep 2012 20:46 #11 by jmmbb
Yes, disconnect and flush the cache... :(
Very strange because new projects are visible and project 138 can be accessed and updated via project screen.
06 Sep 2012 23:10 - 06 Sep 2012 23:12 #12 by babynus
Yes, very strange :huh:
What is the code of the project type "Applicatif" ?
Could you try to update some field in the "progress" part of the project and try again ?
Could you try to change Project status ?
Does it change something ?
Could you check database, table planningelement for lines with refType='Project' and refId='86' ? How many lines ?
What version of Project'Or RIA ?
Did the issue appear with some new version or was it always the behaving this way ?
Thx
Last edit: 06 Sep 2012 23:12 by babynus.
