ProjeQtOr free project management software - PDF print not working - ProjeQtOr
21 Aug 2012 07:42 - 21 Aug 2012 07:43 #1 by jucamvil
Hi.
When I try to use the Export to PDF button it doesnt work.
For instance, from projects Menu, I click on pdf buttond and It opens the page: http://MyDomain/projectorria/view/print.php?print=true&page=../tool/jsonQuery.php&objectClass=Project&objectId=&outMode=pdf&objectType=%20
But It doesnt create the pdf file
I have the 2.4.3 version
Thanks,
Juan
Last edit: 21 Aug 2012 07:43 by jucamvil.
21 Aug 2012 12:06 #2 by babynus
Replied by babynus on topic Re: PDF print not working
Did you try to export to PDF the list of projects of the detail of a project ?
Did you try to wait a bit ? (pdf generation may take some time)
Can you check your log file and copy here any issue reported ?
21 Aug 2012 15:06 #3 by jucamvil
Replied by jucamvil on topic Re: PDF print not working
babynus wrote: Did you try to export to PDF the list of projects of the detail of a project ? The project list and the detail. It was an example, because It happens everywhere with the PDF button.
Did you try to wait a bit ? (pdf generation may take some time) Yes.
Can you check your log file and copy here any issue reported ? No issues:
2012-08-21 08:03:53 ===== TRACE ===== NEW CONNECTED USER 'jvillamizar'
21 Aug 2012 20:10 - 21 Aug 2012 20:10 #4 by babynus
Strange :huh:
Which browser / version are you using ?
Did you try another another version ?
Can you try same thing on Demo ? What is the result ?
Last edit: 21 Aug 2012 20:10 by babynus.
21 Aug 2012 22:56 - 21 Aug 2012 22:57 #5 by jucamvil
babynus wrote: Strange :huh:
Which browser / version are you using ? FF 14.0.1 - Chrome 21 IE 9
Can you try same thing on Demo ? What is the result ? It works.
Last edit: 21 Aug 2012 22:57 by jucamvil.
21 Aug 2012 23:02 - 21 Aug 2012 23:07 #6 by jucamvil
I see URL is not getting the ObjectId parameter....
http://172.16.11.209/projectorria/view/print.php?print=true&page=../tool/jsonQuery.php&objectClass=Alert&objectId=&outMode=pdf
Last edit: 21 Aug 2012 23:07 by jucamvil.
