ProjeQtOr free project management software - PDF print not working - Page 2 - ProjeQtOr
22 Aug 2012 12:01 #7 by babynus
Replied by babynus on topic Re: PDF print not working
Which browser / version are you using ? FF 14.0.1 - Chrome 21 IE 9
So, it does not seem to be browser based issue...
Can you try same thing on Demo ? What is the result ? It works.
So sure it is a server based issue.
What is you server : is it a local install, a server on your own or a hosted server ?
Pay attention to some free hosting services that include adds to your pages : they modify the http response, and pdf pages will possibly not be displayed from these servers.
I see URL is not getting the ObjectId parameter...
It's not an issue : objectId is not set if you print the list.
22 Aug 2012 15:59 - 22 Aug 2012 16:03 #8 by jucamvil
Replied by jucamvil on topic Re: PDF print not working
babynus wrote: What is you server :
It is a local server (Windows Server 2008 R2 - WAMP). Everything works like a charm, excepting for the PDF option.
Maybe Am I missing any configuration? or permissions?
Last edit: 22 Aug 2012 16:03 by jucamvil.
22 Aug 2012 20:30 #9 by babynus
Could you try :
- open Firefox or Chrome, with console opened
- in user parameters screen, select "pdf export in new wintdow to" "Yes"
- generated pdf
=> does the new window open ?
=> do you get a response from server or is the browser waiting for resonse ?
=> if you get a response, what is it ? can you post here the header of the response ?
22 Aug 2012 22:41 #10 by jucamvil
babynus wrote: Could you try :
- generated pdf
=> does the new window open ? Yes. Always.
=> do you get a response from server or is the browser waiting for resonse ? I get response. Blank page shown in 108ms
Header:
Cache-Control:no-store, no-cache, must-revalidate, post-check=0, pre-check=0Connection:Keep-AliveContent-Length:0Content-Type:text/htmlDate:Wed, 22 Aug 2012 20:39:48 GMTExpires:Thu, 19 Nov 1981 08:52:00 GMTKeep-Alive:timeout=5, max=99Pragma:no-cacheServer:Apache/2.2.22 (Win64) PHP/5.3.13X-Powered-By:PHP/5.3.13
25 Aug 2012 16:18 - 25 Aug 2012 16:19 #11 by babynus
You have a header issue.
Here is the header I get :
HTTP/1.1 200 OK
Date: Sat, 25 Aug 2012 14:12:11 GMT
Server: Apache/2.2.21 (Win32) PHP/5.3.9
X-Powered-By: PHP/5.3.9
Expires: Sat, 26 Jul 1997 05:00:00 GMT
Cache-Control: public, must-revalidate, max-age=0
Pragma: public
Last-Modified: Sat, 25 Aug 2012 14:12:12 GMT
Content-Length: 601552
Content-Disposition: inline; filename="document.pdf";
Keep-Alive: timeout=5, max=100
Connection: Keep-Alive
Content-Type: application/pdf
You should try from demo : you should get the same header.
What is most important is the Content-Type, that should be application/pdf; yours is text/html. As you recieve some pdf format, your browser cannot translate this into html and displays a blank page.
You must check your web browser, it must automatically change the header depneding on extension of page name : he automatically assumes to be htms/text because page name extension is .php
Last edit: 25 Aug 2012 16:19 by babynus.
25 Aug 2012 16:38 - 25 Aug 2012 16:59 #12 by babynus
If you use apache, header content-type can be automatically changes from mime.type configuration file :
text/html php
Remove the .php extension.
Restart your web server and test again : it should work better, as apache will keep the defined content-type
Last edit: 25 Aug 2012 16:59 by babynus.
