ProjeQtOr free project management software - assignee is not working - ProjeQtOr
30 Jul 2012 12:21 #1 by yoyomc
I have an issue with the assignee on an activity: Since the v2.4 version, I can not add assignee on an activity, it seems the button is not working.
In fact, there is no action following my click on the "+" button
Do you have a solution ?
Many thanks
30 Jul 2012 12:47 #2 by babynus
Replied by babynus on topic Re: assignee is not working
You should have a javascript eror reported.
Since V2.4 implements new version of Dojo framework, you must refresh your browser cache.
If this does not fix the issue, please report any javascript error.
30 Jul 2012 12:54 #3 by yoyomc
Replied by yoyomc on topic Re: assignee is not working
Thanks for your reply.
I have refreshed my browser cache but the problem still exists, even if I use other browser (I have tested with Chrome, Firefox and IE)
When I click on the "+" button, Chrome gives me the following error details:
Uncaught TypeError: Object [object Object] has no method 'query'
projectorDojo.js:15
Do you have an idea of the problem ?
Many thanks.
30 Jul 2012 14:51 #4 by babynus
Sure you don't have the correct Dojo version.
V2.4.0 has upgraded to Dojo 1.7.2, and some changes have been made.
Possibly, the "external" directroy has not been correctly deployed.
I advise you to upgrade to Project'Or RIA V2.4.1 : it includes some fixing and upgrade to Dojo 1.7.3+.
30 Jul 2012 18:10 #5 by yoyomc
In fact I have already installed the latest version but the problem still exists.
I have tried again copying the external folder but same result :(
Do you have an other idea ?
Many Thanks
30 Jul 2012 19:26 #6 by babynus
Try and refresh the PHP cache.
(restart server)
When done, refresh your browser cache [F5].
