ProjeQtOr free project management software - assignee is not working - Page 2 - ProjeQtOr
30 Jul 2012 19:47 #7 by babynus
Replied by babynus on topic Re: assignee is not working
Could you also try the Demo version : do you reproduce the issue ?
01 Aug 2012 15:57 #8 by yoyomc
Replied by yoyomc on topic Re: assignee is not working
The demo version works fine
How can I try to re-install the latest Project Or RIA version as I have already installed it ?
01 Aug 2012 17:37 #9 by babynus
Just copy the files over existing ones.
You can also try to rename your existing Project'Or RIA directory and install as a brand new "clean" version.
You'll then have to copy to the new directory (from old one) :
- /files directory
- /tool/parametersLocation.php file
- /logo.png file (if you defined your onw logo file)
That's all !
02 Aug 2012 14:26 #10 by yoyomc
Problem fixed !
In fact, it seems the problem was due to the view/ directory. As I have defined new logo, I haven't updated this directory.
But please note the problem always exists if I use Chrome browser, it is ok with Firefox.
Thanks for your help
02 Aug 2012 18:20 #11 by babynus
happy to know you fixed your ploblem.
Just notice that you can easily define your own logo : you just have to copy it at the root of the application. This way, it will not be erased by new versions.
06 Aug 2012 11:34 #12 by yoyomc
Good idea :)
Many thanks
