ProjeQtOr free project management software - ticket reports problem - ProjeQtOr
08 Jun 2012 13:53 #1 by ekolossov
I am getting errors for year reports:
Fatal error: Call to undefined function imageftbbox() in /var/www/localhost/htdocs/projectorria/external/pChart/pChart.class on line 556
Fatal error: Call to undefined function imageftbbox() in /var/www/localhost/htdocs/projectorria/external/pChart/pChart.class on line 1044
Evgueni
08 Jun 2012 14:19 #2 by babynus
Replied by babynus on topic Re: ticket reports problem
What is the exact name of reports generating the anomaly ?
08 Jun 2012 14:21 #3 by babynus
Could you check this and report whether GD is installed on your server and in what version?
08 Jun 2012 14:28 #4 by ekolossov
error 1: tickets->yearly report for tickets
error 2: tickets->report for opened tickets - yearly
08 Jun 2012 14:49 #5 by ekolossov
We have done complete GD install (2.460.0) and it still the same
08 Jun 2012 14:53 #6 by babynus
Ok, this confirms that it concernes reports with graphs.
This must also be produced on the same "monthly" reports.
Two ways to fix :
1) Check you GD librairy, version installed and status of installation.
Graph generation uses pChart, and pChart requires the GD and FreeType PHP extensions to be installed on your web server. This is an important prerequiste that can't be overrided.
2) update /report/header.php, from line 32, from :
$graphEnabled=true;
if (! function_exists('ImagePng')) {
  $graphEnabled=false;
  errorLog("GD Library not enabled - impossible to draw charts");
to
$graphEnabled=true;
if (! function_exists('imageftbbox')) {
  errorLog("GD Library version incorrect or not correctly installed - impossible to draw charts");
The following user(s) said Thank You: ekolossov
