ProjeQtOr free project management software - ticket reports problem - Page 2 - ProjeQtOr
08 Jun 2012 15:17 #7 by ekolossov
Thanks - problem been with FreeType PHP extensions. Now it works!
14 Jun 2012 11:31 #8 by Benoit
Replied by Benoit on topic Re: ticket reports problem
Hello EveryBody,
Sorry I'm not sure my question is in the best TOPIC, but i don't find a topic about this question :
I just tested V2.2.3, and now impossible to see a complet planning with all project, is it normal, please ?
Thank you for your help
Best regards
14 Jun 2012 12:31 #9 by babynus
Replied by babynus on topic Re: ticket reports problem
You're right ! :)
it's not the good topic. :angry:
The answer to your question is : 42.
but maybe you did not understand the question :P
(I didn't) :( .
I cannot analysis issues of kind : it seems it does not work.
Please detail your uses case.
14 Jun 2012 13:47 #10 by Benoit
Sorry, I don't understand :
I try to explain my question :
In version V2.1.1, when you go in "Planning" sheet , you can see all projects
Now in version V2.2.3, when you go in "Planning" sheet, you recieved an alert : "Please choose a project".
Is it possible to have the same as V2.1.1 in this sheet, please ?
(Sorry for my english, I'm french :()
Best regards,
14 Jun 2012 13:52 #11 by ekolossov
No, no, no - we are not going to wait forever until Gantt chart loaded. If you want all the projects, you can make them subprojects of the one and in this case you will see all the subprojects on the same Gantt chart...
14 Jun 2012 13:59 - 14 Jun 2012 13:59 #12 by babynus
Read Douglas Adams !
(sorry, private joke) :lol:
this is a performance improvement since V2.2.
If you have visibility to all projects (admin profile) and there are more than "maxProjectsToDisplay" projects in your database, then the blocking you get appears.
It just invites you to select a project in the project selector, to limit visibility.
This way, you will avoid trying to display thouthands of items, and crach your server.
You can also increase the maxProjectsToDisplay in the parameter table to avoid this blocking...
So am I. Cannot be healed. Sorry. :P
Last edit: 14 Jun 2012 13:59 by babynus.
The following user(s) said Thank You: Benoit
