ProjeQtOr free project management software - Documents download problem - Page 2 - ProjeQtOr
25 May 2012 12:09 #7 by ekolossov
I have tried with Firefox and IE - result id the same...
So somehow upload changing encoding to UTF-8
30 May 2012 00:06 #8 by babynus
I worked on this issue and could not reproduce your upload issue.
I'm afraid I must be able to reproduce to find a workaround.
I also tried to change default encoding, but with no success.
Can you tell me what your encoding charset is ?
(on Firefox : Tools / Options / Content / Advanced button (on fonts) / encoding charset)
05 Jun 2012 16:29 #9 by babynus
Hi Evgueni,
I still try to fix this issue but whatever I try, I cannot reproduce.
- are you still facing the issue ?
- Can you tell me what your encoding charset is (on your browser configuration) ?
- on your first posts, you said the file was OK on server, but KO when downloading, but when you tried it on Demo, I got a wrong format on the server (with some UTF-8 translation), and after fixing on server, I could download OK. Could you confirm the diagnostic : file OK on server (error on download) of file KO on server (error on upload).
06 Jun 2012 09:11 #10 by ekolossov
Default is Western (ISO-8859-1)
06 Jun 2012 13:07 #11 by ekolossov
Ok, we have found and fixed the problem:
Added the ob_clean() and flush() command before the readfile in download.php
e.g., in tool/download.php
ob_clean();
flush();
readfile($file);
Now everything is OK - please implement into main stream
Evgueni
06 Jun 2012 13:42 #12 by babynus
Great you found a fixing !
I'll try it to include it in next version.
I want to investigate about the flush() method : not sure the result will be the same on Windows (flush does not immediatly sends result to browser) and Linux (flush immediatly sends result to browser). I'll test it before including it.
Many thanks.
