ProjeQtOr free project management software - Documents download problem - Page 3 - ProjeQtOr
06 Jun 2012 14:40 #13 by babynus
You solution works fine on my windows environment, but fails on my Linux environment :
ERROR : ob_clean()
failed to delete buffer. No buffer to delete
in download.php
at line 51
It seems that ob_clean() fails on Linux if buffer is empty.
In your case, your server should add some extra characters that fills the buffer (leading to original download issue).
I fixed this way :
if (ob_get_length()){
    ob_clean();
  flush();
This solution brings no regression for me. Tested :
- with Windows XP and Linux servers
- using browser : Chrome 19, Firefox 12 and IE 8
- downloading : ticket attachment file, document version file
Could you please test this solution and confirm that it still fixes the issue in your case ?
06 Jun 2012 14:49 #14 by ekolossov
Used your code and still seems to work.
(Oddly enough we're running a linux server....)
Evgueni
06 Jun 2012 17:25 #15 by babynus
Great !
So this fix will be included in V2.3
