ProjeQtOr free project management software - 2.2.0 : plannig calculation - Page 2 - ProjeQtOr
09 May 2012 15:47 #7 by ffwrude
I'd like to know if there is a workaround or if i can go back to the old version without problem.
09 May 2012 15:52 #8 by babynus
Just change value in table parameter for line with
parameterCode=maxProjectsToDisplay
and change
parameterValue=25
to a value > max of projects in your database.
This should work.
09 May 2012 16:05 #9 by ffwrude
Works fantastic. Thank you.
10 May 2012 11:57 #10 by ThierrC49
Hello Babynus,
I have made the modification in database that remove the first message :) , but when I want to calculate project the list of available project still empty :blush:
Any idea? do you think that my user configuration is bad, I'm trying in admin mode then I suppose I can do all :D ?
Thx
Thierry,
10 May 2012 14:35 #11 by babynus
It's a bug.
Regression from V2.1.1
Ticket registered #667.
To be fixed on next patch
The following user(s) said Thank You: ThierrC49
14 May 2012 10:32 #12 by ffwrude
Just upgraded to 2.2.2 and i still have to go around and modify in the database. It's still telling me "Please select one project".
