ProjeQtOr free project management software - 2.2.0 : plannig calculation - ProjeQtOr
07 May 2012 16:07 #1 by ThierrC49
Hello Babynus,
I don't able to recalculate the planning since the 2.2.0 version. I have an user affected to this task with rigth to do this, but when he go to planning this message appear :
"you must select a project"
If I click on "calculate button" to recalculate all planning the project list is empty and message ask me to select a project.
The structure of project is :
Default project
|Prj1
|Prj2 and so one
The user in charge of planning is a resource affected to default project with rigth access to calculate, planning and affectation.
Thanks for your help
Thierry,
07 May 2012 21:31 #2 by ThierrC49
To be sure and because i'm testing your new software, I have tried to come back to old version (2.1.0) with old database and the project button work fine, I just update projector'ria login and after this operation the calculate button don't work.
I hope this information help you to reproduce issue, I can send you my database if you want
BR
Thierry,
08 May 2012 08:20 #3 by climb4fun
Hi Babynus,
I confirm this issue - that's the same I reported yesterday. It occurs even when "all projects" in project selector.
Klaus
08 May 2012 11:13 #4 by babynus
first be sure to refresh your broser cache when testint from one version to the other (including when you reverse to old version).
Then, new message is normal : it is a restriction to avoid performance issue when dealing with many projects.
When user has visibility to all projects, and existing projects number is over value defined in maxProjectsToDisplay parameter (25 by default), then the user must select a project to limit scope when entering planning screen and lauching planning.
08 May 2012 12:53 #5 by climb4fun
Hi Babynus,
just tested in your test enviroment. It is the same behaviour.
Then I selected project "Test 1" and started calculation, which led to following error (reproducable):
Error on finalizeMessageDisplay('planResultDiv') : Destination or is not a node or not a widget or lastOperation or lastOperationStatus is not a node
Fatal error: Allowed memory size of 67108864 bytes exhausted (tried to allocate 83 bytes) in /home/o101506/public_html/projectorria/test/model/persistence/Sql.php on line 85
Klaus
08 May 2012 19:59 #6 by babynus
It's a memory limit issue.
I'll fix it.
