ProjeQtOr free project management software - planning screen with weird alignment - Page 2 - ProjeQtOr
05 Sep 2024 10:26 #7 by CédricPeter
I use the latest version of Brave.
The problem is also present on Edge.
In the Gantt view, I do a search with Ctrl+F and when I scroll down, I see the offset appear.
That said, I don't necessarily need to do a search for the problem to occur.
05 Sep 2024 11:04 #8 by babynus
This issue occurs when you use a zoom in the browser.
Just set zoom to 100% will remove the issue.
This issue is fixed on V11.3.2, where you can use zoom without issue (I just tested on Brave, works fine)
Please note that we do not bring free support to "old" versions.
Please migrate to latest stable release or consider subscribing to professional support.
05 Sep 2024 12:24 #9 by CédricPeter
I update the new version a soon as they are released. I'm using the last version v.11.3.2.
The problem happened to me still today without changing zoom. (I've nerver zoomed by purpose to use Projeqtor).
I will keep an eye on what's going on.
