ProjeQtOr free project management software - planning screen with weird alignment - ProjeQtOr
06 Mar 2024 08:11 - 06 Mar 2024 08:12 #1 by CédricPeter
in version 11.1.5 I noticed an offset in the alignment in the schedule display. The more items, the greater the offset.
Last edit: 06 Mar 2024 08:12 by CédricPeter.
06 Mar 2024 08:54 #2 by maxca
I could not reproduce this issue. Which browser do you use? Are you using some Zooming in the browser ? it may be a cache effect > refresh cache.
Don't hesitate to describe what you've done so that we can solve the problem.
Thank you
Maxca
06 Mar 2024 12:40 #3 by CédricPeter
Brave Version 1.63.165 Chromium: 122.0.6261.94 (Build officiel) (64 bits)
I opened projeqtor and the same problem happened.
I changed day scale to week, month and reput day.
I checked the zoom, it was at 100 %, changed it to 90 and reput to 100 %. The problem disapear.
Thank you for your prompt reply.
08 Mar 2024 08:41 #4 by maxca
We've tried on several PCs and browsers following what you've said, but we can't reproduce your case.
Do you have errors in your logs? Or/ and in the console?
Maxca
08 Mar 2024 09:27 #5 by CédricPeter
It's happened again this morning.
I manage this issue by changing day scale to week scale and going back to day scale.
2024-03-08 08:20:28.480 ***** ERROR ***** [V11.1.5] Exception-[42S22] SQLSTATE[42S22]: Column not found: 1054 Unknown column 'pe.refId' in 'where clause'
2024-03-08 08:20:28.481 ***** ERROR ***** [V11.1.5] For query : select * from delivery where ( exists (select 'x' from assignment ass where ass.refType='Meeting' and ass.refId = pe.refId and ass.idResource=3 AND exists ( select 'x' from meeting meet where id = ass.refId AND meet.idStatus IN (10, 3, 11))) or exists (select 'x' from meeting meet where id=pe.refId and meet.idResource=3 AND meet.idStatus IN (10, 3, 11)) ) and pe.done=0 and pe.idle=0 and refType='Meeting' and validatedEndDate>='2024-03-04' and validatedEndDate<='2024-03-10' and pe.idProject in (0, 4, 5, 20, 19, 45, 22, 3, 39, 21, 52, 2, 46, 16, 17, 11, 25, 35, 26, 27, 28, 29, 30, 31, 32, 33, 36, 37, 12, 47, 13, 15, 41, 38, 14, 6, 44, 40, 43, 48, 7, 8, 9, 10, 18, 23, 49, 24, 42, 50, 51) AND idStatus IN (10, 3, 11) and done=0 and idle=0 and ( ( realDate is null and plannedDate is null and initialDate>='2024-03-04' and initialDate<='2024-03-10' ) or ( realDate is null and (plannedDate>='2024-03-04' and plannedDate<='2024-03-10') ) or ( (realDate>='2024-03-04' and realDate<='2024-03-10') ) ) and idProject in (0, 4, 5, 20, 19, 45, 22, 3, 39, 21, 52, 2, 46, 16, 17, 11, 25, 35, 26, 27, 28, 29, 30, 31, 32, 33, 36, 37, 12, 47, 13, 15, 41, 38, 14, 6, 44, 40, 43, 48, 7, 8, 9, 10, 18, 23, 49, 24, 42, 50, 51)
2024-03-08 08:20:28.481 ***** ERROR ***** [V11.1.5] Strack trace :
2024-03-08 08:20:28.481 ***** ERROR ***** [V11.1.5] #0 Sql->query called at [C:\xampp\htdocs\projeqtor\model\persistence\SqlElement.php:2983]
2024-03-08 08:20:28.481 ***** ERROR ***** [V11.1.5] #1 SqlElement->getSqlElementsFromCriteria called at [C:\xampp\htdocs\projeqtor\view\diary.php:386]
2024-03-08 08:20:28.481 ***** ERROR ***** [V11.1.5] #2 getAllActivities called at [C:\xampp\htdocs\projeqtor\view\diary.php:161]
08 Mar 2024 10:11 #6 by maxca
All right, thanks. There's nothing in the logs to explain that. Does your problem persist on another browser?
- Try updating your Brave browser and let us know if it persists.
- Also, try switching to Firefox or/ and Chrome and let us know if you get this error.
Maxca
