ProjeQtOr free project management software - [SOLVED] Adding public holidays in standard calendar doesn't work - Page 2 - ProjeQtOr
10 Mar 2023 16:50 #7 by babynus
Could you please try and install the attached patch (install it like a plugin). It adds some debuging traces.
Set log level to debug.
Clear log file.
Execute the fucntion that gives no result.
Post resulting log file.
Thx
13 Mar 2023 08:55 #8 by kbcgwi
I have installed the plugin, and redo the operation (log file attached).
It seems that the issue is about access rights.
I am connected with the admin profile in Projeqtor.
13 Mar 2023 09:05 #9 by kbcgwi
I found the solution.
I don't know why (and how), but the Administrator profile right for the standard calendar was set to "Reader" instead of Manager (I don't remember changing these settings).
Thank you for your help.
