ProjeQtOr free project management software - [SOLVED] Adding public holidays in standard calendar doesn't work - ProjeQtOr
09 Mar 2023 12:29 #1 by kbcgwi
Since the beginning of the year, we can't add the public holidays in the standard calendar. We did it each year before, and we never have any problem.
When we click on the button, it don't show any error, but the days are not set as public holidays. And in the "imputation" view, the related days are not greyed out.
I just try after update to the newer version (V10.2.3), but the result is the same.
It is a bit problematic for us because these public days off are not taken in account for the planning calculation.
09 Mar 2023 18:13 #2 by babynus
Cannot reproduce.
All works fine on my instances.
Do you have any error in log file ?
10 Mar 2023 08:50 #3 by kbcgwi
Please find attached the log file while trying to add public holidays in calendar (in Script log level), but no error are shown.
10 Mar 2023 09:17 #4 by babynus
No error in log (NB : script log level not necessary, we look for errors)
Can you explain how you add the holidays ? Some screenshots ?
10 Mar 2023 09:27 #5 by kbcgwi
I set the script log level because with the other levels, I don't see anything in the log file.
Attached is a screenshot of the calendar view, but I don't think that you will see something wrong (I click on "Add these public holidays to calendar", but only the weekend days are marked as days off).
Also, when I click on a specific day on the calendar on the bottom, nothing happen too, the day is not marked as a day off.
I try to create a new standard calendar, but the result is the same.
10 Mar 2023 16:30 #6 by babynus
Strange, no issue , no erreur.
Do you connect as admin to manage the calendar ?
