ProjeQtOr free project management software - problem with email to ressource working part time if timesheet not fully entered - ProjeQtOr
20 Oct 2022 17:18 - 21 Oct 2022 12:08 #1 by jeanmoulin
I have a problem when I set up the system to send emails to ressources
This browser does not support PDFs. Please download the PDF to view it: Download PDF
that did not entered a full timesheet (Génération d'alertes si les imputations ne sont pas renseignées)
it works fine for the ressources working full time, but I have problem with the part time.
it is ok for ressources working 80% but not for ressources working 50%
In the global parameters the system is set up to send an email to the ressources that did not submit a full timesheet with the option « Oui, contrôlé globalement sur la période
For the first ressource , working 80 %, no problem : when she imputs a timesheet with 4 days, she doesn’t get an email, and if she inputs a timesheet with for instance 3 days she gets an email
But it doesn’t work for the second ressource working 50 % : she gets an email even if she inputs a timesheet with 2,5 days
see screen shots in the attached file
Is it something I did wrong or a bug ?
Last edit: 21 Oct 2022 12:08 by jeanmoulin.
27 Oct 2022 11:44 #2 by babynus
What version of PrpjeQtOR are you using ?
I think we fixed some issue about rounding values to generate the alert, possibly you're in that case.
27 Oct 2022 12:05 #3 by jeanmoulin
Sorry I should have told you what my version is. I'm running ProjeQtOr V10.0.6
I plan to upgrade to 10.1.3 as soon as it is available and to 10.2 as soon as it will be released.
I can check again once I'll be in 10.1.3 and let you know if it solved the problem or not
regards
05 Dec 2022 09:01 - 07 Dec 2022 18:18 #4 by jeanmoulin
I'm now running version 10.1.3 and the problem is not corrected
for instance a ressource working part-time 50% and inputing 2.5 days receives the warning email
here are  :
- the email parameters
- the ressource
- the values inputed
- the email received
Last edit: 07 Dec 2022 18:18 by babynus.
07 Dec 2022 18:24 #5 by babynus
Well that's right, alert should not have been sent.
Possibly the option to control globally was not taken into account.
Could you please try and stop/restart CRON to be sure ?
08 Dec 2022 09:55 #6 by jeanmoulin
OK, I just I did a start / stop of the cron.
I inputed some work, and will let you know the result monday
regards
