ProjeQtOr free project management software - problem with email to ressource working part time if timesheet not fully entered - Page 2 - ProjeQtOr
12 Dec 2022 08:24 #7 by jeanmoulin
I checked this morning and stopping / restarting the cron didn't change anything
12 Dec 2022 14:39 #8 by babynus
OK,
We'll have a look.
Ticket #6765 recorded
27 Feb 2023 09:27 - 27 Feb 2023 09:28 #9 by jeanmoulin
I'm now running projeqtor 10.2.1 that is supposed to correct Ticket #6765
I stopped and restarted the cron before testing
I'm sorry but it still doesn't work : I have 2 ressources, working part time 50% and 80% , I inputed a time sheet with 20 days instead of 2.5 for the 50% ressource and 3 days instead of 4 for the 80% ressource, and no email is sent
see the system parameters in the attached pdf file pb-temps-partiels-20230227.pdf
regards
Last edit: 27 Feb 2023 09:28 by jeanmoulin. Reason: add attachment
02 Mar 2023 09:04 #10 by babynus
Alert is sent on Saturday only.
Resource that has recorded 20 days instead of 2.5 won't receive message as you selected "only uncomplete".
Second resource should have receive the Alert.
Are you sure :
 - this resource has an email
 - this resource has access to Timesheet screen
02 Mar 2023 09:23 - 02 Mar 2023 09:25 #11 by jeanmoulin
"Alert is sent on Saturday only" ==> yes I know and it works fine with people working 100% they get the alert on saturday
'Resource that has recorded 20 days instead of 2.5 won't receive message as you selected "only uncomplete" ' ==> oups, sorry it's my mistake : I wrote that the ressource recorded 20 days instead of 2.5 : it is a typing mistake : I wanted to write that the ressource recorder 2 days instead of 2.5 (see screenshots in the attached file)
Second resource should have receive the Alert. ==> yes and first too since it recorded 2 days (and not 20) instead of 2.5
Are you sure :
 - this resource has an email ==> yes both ressources have an email, both the same : it is my email (both ressources are test ressources that I created only for testing purposes). My email works fine because I work full time and when I record less than 5 days in a week I get a warning email.
 - this resource has access to Timesheet screen ==> NO THEY DO NOT : has you can see in the screnshots in the attached file these ressources profile's is "aucun access" (access to nothing) : I recorded their timesheet using my admin access. Since their are only test ressources that I created to test they do not need to access anything. Also there is no user associated with this ressource.. Could this be the cause of the problem ?
Last edit: 02 Mar 2023 09:25 by jeanmoulin.
02 Mar 2023 09:27 #12 by babynus
Yes, this is the source of the issue : we never send alert emails for incorrect Timesheets to resources that don't have access to Timesheet screen.
It's an evolution that was requested on the forum ;)
