ProjeQtOr free project management software - Project recalculate - ProjeQtOr
Project recalculate
23 Jan 2012 17:04 #1 by ekolossov
Recalculation sometimes producing unexplained results like assigning real(h) to value like 40,960.00 and there is no way to fix this issue.
Another issue with recalculation is that tasks start date is moving independently from the start date set for task, so it creating a complete mess.
There is no way to submit screenshot which will be useful for explanation.
Evgueni
23 Jan 2012 19:03 #2 by babynus
Replied by babynus on topic RE : Project recalculate
Please submit screenshot to This email address is being protected from spambots. You need JavaScript enabled to view it..
Move start date may depend on planning mode : see planning description in Manual, it may help.
24 Jan 2012 08:58 #3 by ekolossov
Replied by ekolossov on topic RE : Project recalculate
I have been looking at manual but still in many cases project recalculation is unpredictable....
26 Jan 2012 16:45 #4 by ekolossov
Looking like I found the source of the problem. The problem is in assignment of hours to developer. Without it recalculation is working Ok but after assigning hours it unpredictable. I suspect it (sometimes) recalculating project taking this hours as a days and after that recalculating this hours again. Quite reproducable I would say.
Hope this will help to fix the problem.
Evgueni
26 Jan 2012 17:02 #5 by babynus
Thnaks for the information.
It may help.
29 Jan 2012 16:44 #6 by babynus
I just fixed this issue for V2.0.
This happend when updating assignment with real work, when work is displayed in hours.
Luckily, any new input of real work corrects the value.
If you need to fix it, in /tool/saveAssignment.php
replace line 89 :
$assignment->realWork=$realWork;
with
$assignment->realWork=Work::convertWork($realWork);
