ProjeQtOr free project management software - Project recalculate - Page 2 - ProjeQtOr
Project recalculate
30 Jan 2012 16:16 #7 by ekolossov
Replied by ekolossov on topic RE : Project recalculate
Looking like the fix you provided not working - when work hours assigned to developer it will extend the bar to the beginning of the project for some reason and will calculate the planned hours based on that
Evgueni
30 Jan 2012 17:16 #8 by babynus
Replied by babynus on topic RE : Project recalculate
I don't understand.
The prevoius issue was about work calculation, and you're now talking about gantt chart.
Could you please explain ?
30 Jan 2012 17:41 #9 by ekolossov
I am talking about system response on click button "Calculate activities planning" - this is when system been recalculating work
30 Jan 2012 18:33 #10 by babynus
I realy don't understand.
There is no issue on the planning.
The issue was about real work update when modifying assignment.
The fix fixes this.
But does not correct data.
Can you test :
- find one assingmnt with the error
- go to the "real work input" for resource assigned, and save
- check the assignment : it must be corrected.
- then update again assignement : the real work sould not increase any more with the fix
If you still have an issue, please describe your step by step case (described like above)
