ProjeQtOr free project management software - Menu Left not shown with V9.3.2 - ProjeQtOr
21 Oct 2021 15:57 #1 by Coasterman
I've updated our virtual "offline" envirenment To V9.3.2 for testing
But the menu on the left side is missing.
See screenshot.
21 Oct 2021 16:11 #2 by babynus
If server has no internet connection to access outside resources, disable curl php module
or set parameter "getVersion" to "NO" (either change value in table parameter or enter new value in parameters.pgp ($getVersion='NO';)
21 Oct 2021 17:48 #3 by Coasterman
Unfortunately this doesn't help...
Like php.ini --> allow_url_fopen=off the change of "getVersion" to No in the table parmameter just made the errormessage in the news section disapear.
But the left Menu didn't appear.
It is still hidden empty below "Menu search" and it doesn't matter what i click on the left side or if i show/hide the menu.
The links to the favorites are still working, but there i have also no access to the fault log, because i didn't put the administration in my favorites...
21 Oct 2021 18:10 - 21 Oct 2021 18:10 #4 by babynus
Any error in log file ?
Or in browser console ?
Last edit: 21 Oct 2021 18:10 by babynus.
22 Oct 2021 11:12 - 22 Oct 2021 11:32 #5 by Coasterman
Strange behaviour...
I loaded the snapshot with V9.3.1 before the upgrade to V9.3.2 again and discovered that when i logged in (Username replaced with BlaAdmin), that the menu left was already vanished before the upgrade...
The last entry in the log ( 2021-10-15) was when i tested to the gantt issues with the "special user" (see my other post in the forum, userneame in the Log changed to Bla_guest) and then i didn't login again...
So today (2021-10-22) i logged in with the Adminaccount (BlaAdmin) and menu left did not show the content.
I Logged out, and logged in with the user (Bla_guest), this showed the menu, I logged out again, then logged in with the Admin (BlaAdmin) and the menu left was shown again.
After that i loaded an older snapshot with V9.2.2 and directly updgrade to V9.3.2 which was ok (so it has nothing to do with the upgrade process....)
The "recovery process" worked also with the snapshot of V9.3.2 which didn't show the menu left content.
Cookie problem ?!
After i tested this with Firefox i couldn't reproduce it after a certain time (in the beginning i could load different versions and simulate with different versions etc. ) but now when i go back it doesn't appear again.
But with the Edge browser where I had the same issue and did not play and login logout, i still have it (at the same time with Firefox i don't).
Here is the log with V9.3.1 (replaced // with \\ in the log, otherwise it complaint of too many links)
2021-10-15 17:22:15.025
DEBUG
loginCheck : current db version = 'V9.3.0'
2021-10-15 17:22:15.045
DEBUG
User->authenticate('BlaAdmin', '23af4c11bd5b442979e14d2bc2ced6ecc79b62fc2d69b8b71c25c3e019d9b2d3')
2021-10-15 17:22:15.050
DEBUG
User->authenticate : sha256 encryption
DEBUG
User->authenticate : Successfull login
2021-10-15 17:22:15.063 ===== TRACE =====
2021-10-15 17:22:15.063 ===== TRACE ===== =====================================
2021-10-15 17:22:15.063 ===== TRACE ===== DataBase actual Version = V9.3.0
2021-10-15 17:22:15.063 ===== TRACE ===== ProjeQtOr actual Version = V9.3.1
2021-10-15 17:22:15.065 ===== TRACE ===== =====================================
2021-10-15 17:22:15.065 ===== TRACE ===== VERSION V9.3.1
2021-10-15 17:22:15.072 ===== TRACE =====  2 lines updated into table "reportparameter".
2021-10-15 17:22:15.072 ===== TRACE ===== DATABASE UPDATED
2021-10-15 17:22:15.072 ===== TRACE =====  WITH NO ERROR
2021-10-15 17:22:17.299 ===== TRACE ===== =====================================
2021-10-15 17:22:17.299 ===== TRACE ===== DATABASE UPDATE COMPLETED TO VERSION V9.3.1
2021-10-15 17:22:28.078
DEBUG
loginCheck : current db version = 'V9.3.1'
2021-10-15 17:22:28.094
DEBUG
User->authenticate('BlaAdmin', 'efd49066e46af061996470b0c30909f768a12a8e0482f8c77a5785ea97ac4965')
2021-10-15 17:22:28.101
DEBUG
DEBUG
2021-10-15 17:22:28.378 ===== TRACE ===== NEW CONNECTED USER 'BlaAdmin'
2021-10-15 17:22:29.471 ===== TRACE ===== Cannot check Version at http:\\projeqtor.org/admin/getVersion.php
2021-10-15 17:22:29.471 ===== TRACE ===== Maybe allow_url_fopen is Off in php.ini...
2021-10-15 17:23:51.829 ===== TRACE ===== DISCONNECTED USER 'BlaAdmin'
2021-10-15 17:24:02.080
DEBUG
2021-10-15 17:24:02.097
DEBUG
User->authenticate('BlaAdmin', 'b9d2ca2d17afb771fe307ddc0bfb1595ffdd29c83abee9192deed8e97fc5151f')
2021-10-15 17:24:02.102
DEBUG
DEBUG
2021-10-15 17:24:02.343 ===== TRACE ===== NEW CONNECTED USER 'BlaAdmin'
2021-10-15 17:24:03.364 ===== TRACE ===== Cannot check Version at http:\\projeqtor.org/admin/getVersion.php
2021-10-15 17:24:03.365 ===== TRACE ===== Maybe allow_url_fopen is Off in php.ini...
2021-10-15 17:25:17.919 ***** ERROR ***** [V9.3.1] ERROR *****
2021-10-15 17:25:17.920 ***** ERROR ***** [V9.3.1] on file '/var/www/projeqtor/view/refreshLastNews.php' at line (62)
2021-10-15 17:25:17.920 ***** ERROR ***** [V9.3.1] cause = file_get_contents(): php_network_getaddresses: getaddrinfo failed: Temporary failure in name resolution
2021-10-15 17:25:29.898 ***** ERROR ***** [V9.3.1] ERROR *****
2021-10-15 17:25:29.898 ***** ERROR ***** [V9.3.1] on file '/var/www/projeqtor/view/refreshLastNews.php' at line (62)
2021-10-15 17:25:29.898 ***** ERROR ***** [V9.3.1] cause = file_get_contents(): php_network_getaddresses: getaddrinfo failed: Temporary failure in name resolution
2021-10-15 17:47:57.486
DEBUG
2021-10-15 17:47:57.500
DEBUG
User->authenticate('Bla_guest', 'XAH2wY6GaWH9Y2gp+FH29GZWF5Q=')
2021-10-15 17:47:57.505
DEBUG
User->authenticate : no encryption
2021-10-15 17:47:57.510
DEBUG
2021-10-15 17:47:57.797 ===== TRACE ===== NEW CONNECTED USER 'Bla_guest'
2021-10-15 17:51:16.427 ===== TRACE ===== DISCONNECTED USER 'Bla_guest'
2021-10-15 17:51:32.179
DEBUG
2021-10-15 17:51:32.195
DEBUG
User->authenticate('Bla_guest', '718d04e04d661fd1c42cbeb304851d5aabdaf6146345381208c604d78012afcd')
2021-10-15 17:51:32.201
DEBUG
DEBUG
2021-10-15 17:51:32.211 ===== TRACE ===== NEW CONNECTED USER 'Bla_guest'
2021-10-15 17:55:11.840 ***** ERROR ***** [V9.3.1] ERROR *****
2021-10-15 17:55:11.840 ***** ERROR ***** [V9.3.1] on file '/var/www/projeqtor/view/refreshLastNews.php' at line (62)
2021-10-15 17:55:11.840 ***** ERROR ***** [V9.3.1] cause = file_get_contents(): php_network_getaddresses: getaddrinfo failed: Temporary failure in name resolution
2021-10-15 17:55:13.042 ***** ERROR ***** [V9.3.1] ERROR *****
2021-10-15 17:55:13.042 ***** ERROR ***** [V9.3.1] on file '/var/www/projeqtor/view/refreshLastNews.php' at line (62)
2021-10-15 17:55:13.042 ***** ERROR ***** [V9.3.1] cause = file_get_contents(): php_network_getaddresses: getaddrinfo failed: Temporary failure in name resolution
2021-10-15 18:04:35.731 ===== TRACE ===== DISCONNECTED USER 'Bla_guest'
2021-10-15 18:05:07.715
DEBUG
2021-10-15 18:05:07.734
DEBUG
User->authenticate('Bla_guest', '9748d7ccc6c66a6efb71150d39bffb1d2d8078c9cd6d33fd5d49acb835af8da5')
2021-10-15 18:05:07.740
DEBUG
2021-10-15 18:05:07.741
DEBUG
2021-10-15 18:05:07.757 ===== TRACE ===== NEW CONNECTED USER 'Bla_guest'
2021-10-15 18:25:32.169 ===== TRACE ===== DISCONNECTED USER 'BlaAdmin'
2021-10-22 12:37:14.719
DEBUG
2021-10-22 12:37:14.737
DEBUG
User->authenticate('BlaAdmin', '206d0d8407e5e5240d503b32dc2668b47686a3b13114c7691922ba7f99aa37ea')
2021-10-22 12:37:14.743
DEBUG
DEBUG
2021-10-22 12:37:15.020 ===== TRACE ===== NEW CONNECTED USER 'BlaAdmin'
2021-10-22 12:37:16.239 ===== TRACE ===== Cannot check Version at http:\\projeqtor.org/admin/getVersion.php
2021-10-22 12:37:16.239 ===== TRACE ===== Maybe allow_url_fopen is Off in php.ini...
2021-10-22 12:38:02.622 ===== TRACE ===== DISCONNECTED USER 'BlaAdmin'
2021-10-22 12:38:14.083
DEBUG
2021-10-22 12:38:14.097
DEBUG
User->authenticate('Bla_guest', '66360ba95af8e785b5b1ab56df50522fb2f5af90b41b6e5bf872fb0f8102c87b')
2021-10-22 12:38:14.102
DEBUG
DEBUG
2021-10-22 12:38:14.115 ===== TRACE ===== NEW CONNECTED USER 'Bla_guest'
2021-10-22 12:38:36.071 ===== TRACE ===== DISCONNECTED USER 'Bla_guest'
2021-10-22 12:38:47.025
DEBUG
2021-10-22 12:38:47.041
DEBUG
User->authenticate('BlaAdmin', 'c73e7f9b33384373efbc0f2f2035e11567cd645b4afd94f765b40870005dfff0')
2021-10-22 12:38:47.047
DEBUG
DEBUG
2021-10-22 12:38:47.280 ===== TRACE ===== NEW CONNECTED USER 'BlaAdmin'
2021-10-22 12:38:48.373 ===== TRACE ===== Cannot check Version at http:\\projeqtor.org/admin/getVersion.php
2021-10-22 12:38:48.373 ===== TRACE ===== Maybe allow_url_fopen is Off in php.ini...
2021-10-22 12:39:31.165 ===== TRACE ===== DISCONNECTED USER 'BlaAdmin'
2021-10-22 12:39:39.893
DEBUG
2021-10-22 12:39:39.906
DEBUG
User->authenticate('BlaAdmin', '93ef595542b086e6391dab1f5c82b5dbff8c3e6c904e62e7ee7129994763cb5d')
2021-10-22 12:39:39.912
DEBUG
DEBUG
2021-10-22 12:39:40.135 ===== TRACE ===== NEW CONNECTED USER 'BlaAdmin'
2021-10-22 12:39:41.166 ===== TRACE ===== Cannot check Version at http:\\projeqtor.org/admin/getVersion.php
2021-10-22 12:39:41.166 ===== TRACE ===== Maybe allow_url_fopen is Off in php.ini...
2021-10-22 12:42:46.359 ..... SCRIPT .... 192.168.56.1 =====/projeqtor/tool/dynamicDialog.php
2021-10-22 12:42:46.461 ..... SCRIPT .... 192.168.56.1 Page=dynamicDialog.php
2021-10-22 12:42:46.461 ..... SCRIPT .... 192.168.56.1 refreshParameters()
2021-10-22 12:42:46.565 ..... SCRIPT .... 192.168.56.1 getProfile(objectOrIdProject=Audit #109)
2021-10-22 12:42:46.581 ..... SCRIPT .... 192.168.56.1    ->/view/logfiles.php
2021-10-22 12:42:48.348 ..... SCRIPT .... 192.168.56.1 =====/projeqtor/tool/dynamicDialog.php
2021-10-22 12:42:48.442 ..... SCRIPT .... 192.168.56.1 Page=dynamicDialog.php
2021-10-22 12:42:48.442 ..... SCRIPT .... 192.168.56.1 refreshParameters()
2021-10-22 12:42:48.549 ..... SCRIPT .... 192.168.56.1 getProfile(objectOrIdProject=Audit #109)
2021-10-22 12:43:01.771 ..... SCRIPT .... 192.168.56.1 =====/projeqtor/tool/storeLogLevel.php
2021-10-22 12:43:01.864 ..... SCRIPT .... 192.168.56.1 Page=storeLogLevel.php
2021-10-22 12:43:01.865 ..... SCRIPT .... 192.168.56.1 refreshParameters()
2021-10-22 12:43:01.971 ..... SCRIPT .... 192.168.56.1 getProfile(objectOrIdProject=Audit #109)
2021-10-22 12:43:01.996 ..... SCRIPT .... 192.168.56.1 getProfile(objectOrIdProject=Parameter #1766)
2021-10-22 12:43:01.996 ..... SCRIPT .... 192.168.56.1 securityGetAccessRightYesNo ( menuName=menuParameter, accessType=update, obj=Parameter #1766, user=User #3)
2021-10-22 12:43:01.997 ..... SCRIPT .... 192.168.56.1 securityGetAccessRight(menuName=menuParameter, accessType=update, obj=Parameter #1766, user=User #3)
2021-10-22 12:43:01.997 ..... SCRIPT .... 192.168.56.1 getAccessControlRights(obj=Parameter #1766)
2021-10-22 12:43:01.997 ..... SCRIPT .... 192.168.56.1 getProfile(objectOrIdProject=Parameter #1766)
2021-10-22 12:43:05.302 ===== TRACE ===== DISCONNECTED USER 'BlaAdmin'
2021-10-22 12:43:13.816
DEBUG
2021-10-22 12:43:13.832
DEBUG
User->authenticate('BlaAdmin', '5377cacb5463bc96ef94cc6e2606bbe64c89394e4fbc50e5ecbf72269e282550')
2021-10-22 12:43:13.837
DEBUG
2021-10-22 12:43:13.838
DEBUG
2021-10-22 12:43:14.069 ===== TRACE ===== NEW CONNECTED USER 'BlaAdmin'
2021-10-22 12:43:15.144 ===== TRACE ===== Cannot check Version at http:\\projeqtor.org/admin/getVersion.php
2021-10-22 12:43:15.144 ===== TRACE ===== Maybe allow_url_fopen is Off in php.ini...
2021-10-22 12:43:53.150 ===== TRACE ===== DISCONNECTED USER 'BlaAdmin'
2021-10-22 12:43:53.577 ***** ERROR ***** [V9.3.1] Exception-[23000] SQLSTATE[23000]: Integrity constraint violation: 1062 Duplicate entry '6j5p2g4cfu32l8r12iji0v7adf_20211022124353' for key 'auditSessionId'
2021-10-22 12:43:53.577 ***** ERROR ***** [V9.3.1]    For query : update audit set sessionId='6j5p2g4cfu32l8r12iji0v7adf_20211022124353' , disconnectionDateTime='2021-10-22 12:43:53' , idle='1'  where id=111
2021-10-22 12:43:53.577 ***** ERROR ***** [V9.3.1]    Strack trace :
2021-10-22 12:43:53.577 ***** ERROR ***** [V9.3.1]    #0 Sql->query called at [/var/www/projeqtor/model/persistence/SqlElement.php:1780]
2021-10-22 12:43:53.577 ***** ERROR ***** [V9.3.1]    #1 SqlElement->updateSqlElement called at [/var/www/projeqtor/model/persistence/SqlElement.php:1237]
2021-10-22 12:43:53.578 ***** ERROR ***** [V9.3.1]    #2 SqlElement->saveSqlElement called at [/var/www/projeqtor/model/persistence/SqlElement.php:820]
2021-10-22 12:43:53.578 ***** ERROR ***** [V9.3.1]    #3 SqlElement->save called at [/var/www/projeqtor/model/Audit.php:357]
2021-10-22 12:43:53.578 ***** ERROR ***** [V9.3.1]    #4 Audit->save called at [/var/www/projeqtor/model/Audit.php:230]
2021-10-22 12:43:53.578 ***** ERROR ***** [V9.3.1]    #5 Audit->finishSession called at [/var/www/projeqtor/tool/saveDataToSession.php:66]
2021-10-22 12:43:53.601 ===== TRACE ===== DISCONNECTED USER 'BlaAdmin'
2021-10-22 12:44:56.877
DEBUG
2021-10-22 12:44:56.892
DEBUG
User->authenticate('BlaAdmin', '14d99b611d39142048c098fdd9bd0262508fe854b7f1d9f0cc686db45e2027b5')
2021-10-22 12:44:56.897
DEBUG
DEBUG
2021-10-22 12:44:57.123 ===== TRACE ===== NEW CONNECTED USER 'BlaAdmin'
2021-10-22 12:44:58.178 ===== TRACE ===== Cannot check Version at http:\\projeqtor.org/admin/getVersion.php
2021-10-22 12:44:58.178 ===== TRACE ===== Maybe allow_url_fopen is Off in php.ini...
Last edit: 22 Oct 2021 11:32 by Coasterman.
22 Oct 2021 12:46 #6 by babynus
This can be a cache issue.
After upgrade, make sure to clean your browser cache.
When you change user, also be sure to have a clean disconnection (use disconnect button, not F5)
