ProjeQtOr free project management software - REPORT ERRORS - Page 2 - ProjeQtOr
REPORT ERRORS
18 Aug 2021 16:14 #7 by babynus
Replied by babynus on topic REPORT ERRORS
It's because you changed the path to reports (in global parameters / system)
You must define a location "in the web root" so that apache can serve it to users.
24 Aug 2021 22:51 #8 by MichelCA
Replied by MichelCA on topic REPORT ERRORS
Thanks for your help and comments.
We did the last comment, but it still shows error, I attach the following images.
In this first image you can see where the "documente root" is located.
In the second image you can see that "document root" has the permissions
But in this third image you can see the specific new path for the folders, and as you can see, all have the permissions and ownership.
If the folders were created, the directories were placed inside "document root", why does it say it has no permissions when you can see that it does?
Also I attach one image of the error in the reports and the last log
2021-08-24 13:09:34.988 ***** ERROR ***** [V9.1.2] on file '/var/www/html/external/pChart2/class/pImage.class.php' at line (164)
2021-08-24 13:09:34.988 ***** ERROR ***** [V9.1.2] cause = imagepng(/var/www/html/files/report/user1_globalCostPlanning_20210824_130934_1.png): failed to open stream: Permission denied
25 Aug 2021 09:42 #9 by babynus
Strange... if user that runs PHP is apache, it should work.
(this is default php user for RedHat-like distros, such as Centos)
Try and chmod 777 the directory report for testing.
25 Aug 2021 13:48 - 31 Aug 2021 04:31 #10 by sD_Dionysus
Replied by sD_Dionysus on topic REPORT ERRORS
Sorry, I mistakenly wrote in this thread, moved my question to a separate topic.
Last edit: 31 Aug 2021 04:31 by sD_Dionysus. Reason: Sorry, I mistakenly wrote in this thread
26 Aug 2021 01:19 #11 by MichelCA
We tried what you told us but the error is the same, the user if it is Apache.
Is there another way to correct the error? It is important to mention that this error also occurs in another enviroment that we have with ProjeQtor.
30 Aug 2021 16:39 #12 by MichelCA
Anybody knows what could be the problem?
Time to create page: 0.070 seconds
